Programming for 1997 Avalon remotebc7359 09-18-2004, 06:05 PM I am looking for instructions for programming my 1997 Avalon remote. I have two remotes for this car and both are "dead" (new batteries in one). I can't believe the dealer wants so much to program this thing. Anyone have the instructions? stephensclan 09-26-2004, 12:09 AM How do do this depends on a lot of things, most significantly if the remote system is factory or was installed by Toyota after coming to the US (at the dock). I have the same problem and found this Tech Service Bulletin to help explain at least where to look. http://rav4world.com/tsb/EL010-01.pdf aa6 10-08-2004, 08:16 AM I found this out from an ebay auction. Here is the link. I have not personnally tried this, but I doubt this business owner would have any reason to post bogus material. Good luck...let us know if it works or doesn's work. http://www.spotco2.com/9597_avalon.html Programming for 95-97 Avalon remote 1. Remove key from ignition 2. Locate bulb failure warning module in truck near left trunk hinge and disconnect electrical connector. 3. Jump pins 2 & 10 of connector with short wire or paper clip 4. Door locks will cycle 5. Press any button on remote keyless entry entry transmitter 6. Door locks will cycle 7. Repeat steps 5 & 6 for another transmitter 8. Remove jumper from connector and reconnect to module NOTE: A max of 2 transmitters can be programmed to a car NOTE: Entering programming mode erases all previously programmed transmitters. Automotive Network, Inc., Copyright ©2012
