Strange "chugging" feeling.Amish_kid 09-18-2004, 08:15 AM I'm really stumped on this. My car whenever the engine is warm (no problems at all with a cold engine) if I either try to pull away at any lower than 2.5k it feels as if it is going to shit it's pants and sputters like hell. Other problem which is pretty much I know is the same problem when I'm driving if I let the rpm's fall under 2.8k or so it starts to chug like crazy but it only happens under slow to moderate acceleration if I put it down over half throttle it won't do it. Feels as if the engine is starved for fuel. Also I have replaced all ignition parts(cap, rotor, plugs wires) so that pretty much gets ruled out. If anyone has any idea's whatsoever I'm willing to try anything. BTW is a 91 rs Thanks!!!1 gismo0184 09-18-2004, 11:55 AM do you have a cai?? Amish_kid 09-18-2004, 12:03 PM Nopers car is 100% stock gismo0184 09-18-2004, 12:20 PM a couple things come to mind. and these are all problems i had. 1. check your exhaust system for small holes--fumes coming out of anywhere other than your tailpipe--you're losing back pressure. 2. check your intake set up--tb, cable, hose, housing. check to make sure everything is as it should be and that there is nothing causing blockage. 3. try taking out the resonator (if you're teg has one) below the airbox. Amish_kid 09-18-2004, 01:30 PM Ok will do integralover 09-18-2004, 01:40 PM do you think you could have gotten bad gas? or when was the last time your fuel filter was changed? or a tune up done? does it do this all the time or periodically? is your coolant level full? <--believe it or not this can be a problem. gismo0184 09-18-2004, 01:49 PM it can really be any number of things, just check what we've listed and if you still can't figure it out--might be time to go to the shop. Amish_kid 09-18-2004, 02:15 PM Bad gas - Nope Fuel Filter was changed before I got the car I've heard from some people that the o2 sensor on the 90-91's can cause that to happen. And from what other people said it did only happen to them at operational temp. So would it hurt my car if I just unplugged it to see if that might be the case. I know it'll probably run rich just wondering if anything bad can come of it. tran_nsx 09-18-2004, 02:41 PM when did amish people start driving cars? :screwy: Amish_kid 09-18-2004, 02:59 PM The second I also starting violating your mom like a parking meter. :rolleyes: tran_nsx 09-18-2004, 06:05 PM The second I also starting violating your mom like a parking meter. :rolleyes: ok a stupid answer to a good question. talk all the crap u want, ur just lucky ur hiding behind a comp :nono: Amish_kid 09-18-2004, 06:22 PM Lucky Wow! Gee Golly Gosh I Must Be. I have no time for this childish shit you're trying to start. Go look for a fight somewhere else "keyboard warrior". I'm still trying to find the problem with my car, so if you're not going to help out just keep moving along. crazy_canuck 09-18-2004, 07:56 PM I'm guessing its a problem somewhere along the exhaust manifold or exhaust system.....how long has it lasted? knorwj 09-18-2004, 08:02 PM knock it off guys come on, do we relly need this? ok anyway abck to the car, does it sound like your exhaust is kinda gurgleing? and is there a lack of power? I'm having similar problems with my car lately and I just ordered a bunch of tune up stuff friday so if any of them fix it i'll let ya know monday or tuesday. Amish_kid 09-18-2004, 11:40 PM Shouldn't be any problems with the exhaust I know there is a pinhole in the muffler itself. But everything else is pretty much new(read no older than 1 year) with the exception of the manifold. Only 1 thing I can think of now and that would be the o2 sensor I can't find one around here til monday and with my luck I won't have one til next weekend ARRRRRGH!! tran_nsx 09-19-2004, 12:23 AM Lucky Wow! Gee Golly Gosh I Must Be. I have no time for this childish shit you're trying to start. Go look for a fight somewhere else "keyboard warrior". I'm still trying to find the problem with my car, so if you're not going to help out just keep moving along. hold up, im trying to start childish sh*t? i ask u a relatively good, simple, and straight-forward question cause i was curious since ur screen name is amish kid. instead of getting a back an intelligent reply, i get ur bull. whose the one trying to start sh*t? another example of ur stupid reply, look at ur qoute above :nono: don't expect any help from me tran_nsx 09-19-2004, 12:28 AM [QUOTE=knorwj]knock it off guys come on, do we relly need this? QUOTE] knock what off? don't look at me. whose was the one saying they violate other people's mom? wickedplastikman 09-19-2004, 03:03 AM did you already check to see if you are throwing any codes? check all the plugs and wires to make sure you are not missing. Amish_kid 09-19-2004, 08:34 AM hold up, im trying to start childish sh*t? i ask u a relatively good, simple, and straight-forward question cause i was curious since ur screen name is amish kid. instead of getting a back an intelligent reply, i get ur bull. whose the one trying to start sh*t? another example of ur stupid reply, look at ur qoute above :nono: don't expect any help from me Same could be said about you name, do you drive a Trans AM, or maybe even an NSX. No. An Integra Use common sense What about this name wickedplastikman just as an example, do you think he is made of plastik. Or what about gismo0184 do you think he is a God Damned Gremlin or something?! And btw the only way you get an intelligent reply out of me is if you ask me an intelligent question to begin with. Not this " when did amish people start driving cars? " - Ohh tehehe I will be Phunnie. Shit. Amish_kid 09-19-2004, 08:40 AM did you already check to see if you are throwing any codes? check all the plugs and wires to make sure you are not missing. Checked the plugs wires allllllllllllllll ignition parts are no more than 2 months old. How do I check the codes? tran_nsx 09-19-2004, 09:05 AM Same could be said about you name, do you drive a Trans AM, or maybe even an NSX. No. An Integra Use common sense What about this name wickedplastikman just as an example, do you think he is made of plastik. Or what about gismo0184 do you think he is a God Damned Gremlin or something?! And btw the only way you get an intelligent reply out of me is if you ask me an intelligent question to begin with. Not this " when did amish people start driving cars? " - Ohh tehehe I will be Phunnie. Shit. what ur using is not common sense, ur just assuming :rolleyes: hopefully u don't think the integra is the only car i ever had. if u wanted to know why my name is tran_nsx all u have to do is ask :screwy: about ur comment about intelligent question, there is never a stupid question, thats why people ask, unfortunately there are stupid answers from stupid people. :disappoin RSX-S777 09-19-2004, 10:15 AM WHO FUCKING CARES. Let it go, already... knorwj 09-19-2004, 11:14 AM jesus christ you guys suck.... amish, did you replace the little donut gasket between the Y-pipe and cat when you did the exhaust? that may be deteriorated or worn out. integralover 09-19-2004, 11:39 AM :iagree: mine is wearing out and needs to be repalced. but then again i do have a bigger exhaust. i'm just going to go the flex pipe route. integralover 09-19-2004, 11:40 AM WHO FUCKING CARES. Let it go, already... LMAO, there is his people skills again. LOL j/k Amish_kid 09-19-2004, 03:42 PM jesus christ you guys suck.... amish, did you replace the little donut gasket between the Y-pipe and cat when you did the exhaust? that may be deteriorated or worn out. Yeap, they are new. I'm pretty sure it is an o2 sensor because Originally posted by The_Oz Engine stumbles on acceleration - Spark plugs fouled. - Fuel injection system faulty. - Fuel filter clogged. - Incorrect ignition timing. - Intake manifold air leak. - Bad Oxygen sensor. Happens all the time on 90-91 tegs. Engine stutter when warm. I had this problem for 8 or 9 months and couldnt figure out what it was. Everything listed there is pretty much ruled out. bird2431 01-30-2005, 10:39 PM having the same problem here... did anyone find a solution? thanks whtteg 01-30-2005, 10:50 PM I don't think they resolved the issue, if they did I don't think they post here very much anymore so I would just start a new thread with the problem and you will get better results. :) Automotive Network, Inc., Copyright ©2012
