94 Quest EGR valveeddieg 09-17-2004, 02:38 PM where is the egr valve located or where can i see a pic of the location. thanks RedQuest95 09-11-2005, 05:34 PM it is located between the engine (TOP) and the firewall. I just paid $ 500.00 to have mine replaced. It's a dealer only item. IH8SPM 10-31-2005, 06:12 PM If You Have Not Replaced It Yet You Might Want To Go To The Mercury Villager Forum And Read About A Member Who Saved Hundreds By Just Replacing The Hose That Connects To It. Albertobrito 02-15-2006, 01:35 AM I just replaced mine, got the part off ebay and it was not that difficult to do. Good luck rptorain 02-15-2006, 11:10 AM i have never seen an egr valve on a quest go bad 99% of the time it's the hose from the bpt valve to the heat tube. dzus 02-16-2006, 10:38 AM Rockauto.com,about $90 bucks and not all that hard to change. jd-autotech 07-05-2006, 01:15 PM there is two one just toward middle by the master cylinder and if you follow the steel pipe going into it behind the plentum you will find a split open dry rotted tee hose it costs about $17.00 and by the way ignore the knock sensor code Automotive Network, Inc., Copyright ©2012
