How do I install a starter?escortLX361 09-17-2004, 01:18 PM I need to know how to install a starter on my 95 escort 1.9 SEFI. I don't even know where my starter is dawnie28 11-26-2004, 09:06 PM did you find out exactly what it was...i have a 93 escort and im trying to find out where the starter is and i have no clue!! dougand3 11-27-2004, 10:45 AM On the 1.9L....center yourself on the blue ford emblem and lean in...look thru the shiny pipes of the intake manifold on the drivers side (the right side on how you are oriented)...the starter is just below these pipes, fairly high up on the engine...it may say Motorcraft 12v and will be black centrally with aluminum ends...it is a cylinder ~ 10 inches long and ~ 5 inches in diameter. A Haynes manual with instructions on how to remove/re-install is a good idea...~$15 at auto parts shop, such as Autozone, Advance Auto, Oreillys, Pep Boys, etc. Before you replace the starter, have it checked....Autozone will do it for free...there are other possible problems...flywheel damaged, starter solenoid, battery, etc. Automotive Network, Inc., Copyright ©2012
