Has the clutch or tranny totally given out on you yet?
I'm having bearing noise problems, not sure if its just the clutch and or tranny
Is this accompanied by anything mechanically different (ex. does not go in gear, pops out, stuck in gear, gos in gear without the influence of the clutch, etc,etc,etc) other than the audible noise you hear? Because im assuming you are saying you hear a squeek when you step on the clutch. Have you actually popped the hood yet or went under the car to pinpoint where excactly this noise is coming from? Hows the clutch fluid level?
Clarification is needed, because this noise can be other things. Anyways, here are is a nice classified section for you to find a new tranny and clutch (thats if it is that). Other things can be found here too.
http://www.honda-tech.com/zeroforum?id=10
