1998 Cutlass Power Steering Flush
steve_o
09-16-2004, 09:37 AM
3.1 litre Cutlass GLS - I want to flush my power steering fluid, does anyone know the capacity of that system and have suggestions on what brand or type of fluid I should use?
thejacobhartman
09-27-2004, 11:11 PM
first off, why, you should not need to unless you have replaced a part due to contamination or have inadvertently contaminated it yourself.
second flushing the system is a pain without a large reservoir to hold incoming fluid, 2-3 gallons of fresh fluid. other wise you risk burnig up your pump.
the easist way to do it at home with the motor off is to disconnect the lowest point and drain it then reconnect and fill. then run it around the block four or five times. then do it all again a couple of timeswith fresh fluid each time, making sure to top off before leaving the drive way
