2.8L 1985 Timing Marks
OldmanTrucks
09-15-2004, 11:05 PM
Been looking all over the web trying to find out the right timing marks to use for a 1985 2.8L V6 ... manuals all show a timing pointer w/degree markings.. all I have is the picture below:
http://memimage.cardomain.net/member_images/1/web/649000-649999/649862_13_full.jpg
I need to figure out where to time this sucker. I put a rod in the #1 hole and I think the bottom mark -- IE the one by sensor holder but above the "0" in the pick is TDC ... but when I time to that mark the sucker won't start. If I time to the first one, then the puppy runs but won't idle down below about 1200rpm and misses badly at high rpm... low on power lugging to ... anyone seen a harmonic balance like this. This motor has the following:
No Emission Controls left
Offy Manifold
4bbl Holley 390cfm carb
Comp Cams Stage 1 cam
Duraspark-ed non emiss control ignition with old manual distrib
I posted this on a couple of other boards and no luck so far. Hoping someone has seen a setup like the pic and can help.
Twopipe
12-28-2004, 01:58 PM
I was wondering the same thing. I can't find a manual that shows where or what the timing marks mean. If anyone knows please send me a PM. Thanks
Psychopete
12-29-2004, 10:19 AM
What are the spark plugs looking like? Do you hear any vacuume leaks?
