Abs
u195133
09-15-2004, 06:13 PM
i have 2000 Accord EX V6, and I bought it used from another guy, and i know jus recently noticed my ABS doesn't go off. I look under the hood and i see that my ABS wire harness on my driver side is cut. I go to the dealership and say that the wire is 50+ dollars. The weird part though is that I never noticed cause the ABS light never came on. So im afraid even though i replace the wire, ABS would not work...do i need to reset the PCM/ECU or something?
94accordVTEC
09-16-2004, 11:14 AM
go to an electrical store and buy some wire connectors and fix the wire...unless of course the connector is damaged...if you can fix it good then don't worry about buying a new one but this will at least tell you if the ABS works or not.
