PCV Valve
atomicpulse
09-15-2004, 12:37 AM
Where would it be on a 95 Cav 2.2?
BlazerLT
09-15-2004, 02:51 AM
should be in the valve cover.
A hose will go from the pcv valve in the valve cover to the intake.
Very easy to find and should be replaced.
atomicpulse
09-15-2004, 03:18 AM
haha I'll look very closely ;) thanks BlazerLT
BlazerLT
09-15-2004, 03:21 AM
No problem.
Huddy
09-16-2004, 05:00 PM
Is the hose connecting from the intake to the collector box supposed to have a vacuum on it?? I have a 95 2.3 Z24 and it has a vacuum leak below the PCV sensor. I was going to replace the hose when I quickly realized that there was a copper coil inside. Can you just simply replace the hose around it??
BlazerLT
09-16-2004, 05:01 PM
Collector box?
public
09-16-2004, 06:08 PM
PCV Sensor? wtf?
Huddy
09-16-2004, 08:20 PM
There is a hose running from a small black plastic box located in the front of my engine aboce my intake. From this box on the right is a small hose that runs down to the intake manifold. The is a short section of hose the an electronic sensor then another secion of hose connecting it into the manifold. I talked to a Chevy dealer today, they looked at it and told me this was my pcv valve? It has a split in the hose and has a vacuum leak. Is it possible to just replace the rubber hose around this copper wire? The Chevrolet part number is 552. If that helps anyone. I'm obviously a newbie at this, what is the biggest bang for my buck in performance parts. I need all the help I can. Sorry guys.....
BlazerLT
09-16-2004, 08:23 PM
Can you take a picture of this and show us?
