Remote Starter problem pls help!!!!
honda98v6
09-14-2004, 01:10 PM
I installed an Autopage RS-850LCD remote car starter with alarm system and 2-way LCD communication. I got the alarm system to work fine, and some what of the remote starter. The problem is that without the key in the ignition the the car wont start. I have a Honda Accord 98 V6 PLS HELP!!
94accordVTEC
09-14-2004, 01:32 PM
your wiring is screwed up...either 1. you didn't hook up the ignition wires properly... 2. the auto start is drawing power from a wire that is only hot when the key is on or 3. it's something else...lol
1. make sure you hooked up every wire that you need to the correct wire going to the ignition, when you hit the auto start does the car do anything...the auto start has to be able to turn the accessory power first before it can crank.
2. easy enough to check if you have a volt meter...is there power to the unit when the key is off
3. my auto start has a wire that attaches to the plug wires so it knows when the car is running, check that...i also have a hood pin switch that when connected disables the auto start so know one loses a finger when the car starts while your messing with the engine, check that too.
good luck electrical stuff sucks
honda98v6
09-14-2004, 10:23 PM
I think there is a key sensor..everytime i put the key in the ignition the auto start works, but if the key is not in the ignition, then it not work. it only crank but never start
ponchonutty
09-14-2004, 10:30 PM
You sure do have a factory immobilizer. You can use any in the link here but I would use either the 2nd or 3rd if you want to add OEM features to your remote start remotes. http://www.bypasskit.com/wizard.asp
ponchonutty
09-14-2004, 10:31 PM
Whoops, forgot that the link will not show your car automatically. Just put in the model and year and you'll see what I mean. DEI also makes #555h that will work as well. That one you should be able to find locally.
honda98v6
09-14-2004, 11:55 PM
thnx for all the help guys!!
u195133
09-15-2004, 05:49 PM
i had a buddy of mine wire up the autostart for me without the bypass. All he did was wrap a coil of wire around the original key where the sensor is and then hook the end of the wires to the immbolizer input/output sensor. Not as easy as it sounds though, you'll have to fool around wit it for a bit. But it took us a good 1 hour to hour and a half to save 100 bucks.. =)
ponchonutty
09-15-2004, 06:21 PM
That's the cheap easy wrong way to do it. See, you are running a chance of having the car's BCM to read 2 keys at the same time. If it does, it will lock him out permenately. I suggest getting copies of the ignition key (non transponder key) to keep that from happening.
You know, you could have done it right for only about $40 using a 555u from DEI and a new key from Howard Keys.
007COUPE
10-13-2004, 09:56 PM
I have installed a remote start in my 96 accord. You may want to check for a 2nd ignition. Some cars like accords have 2nd ignition wires that you may have to hook the system up to
ponchonutty
10-15-2004, 07:10 PM
No, the newer cars have an immobolizer in the ignition
