Hard Getting Out Of Park
bx10466
09-14-2004, 09:01 AM
It Is Hard Getting The Car Out Of Park On My 92 Accord. Am I About To Have Tranny Problems?
94accordVTEC
09-14-2004, 11:00 AM
More info please...i assume you have an AT but define "hard", does it happen all the time, some of the time...i ask this because there is a lock out that won't let the car out of park unless the brake is pressed if you have this problem sometimes then that solenoid could be going bad or have a bad wire...or is it that it is physically hard to move the lever out of park, this can be asjusted also... :eek7:
SkyydragRx
09-14-2004, 01:05 PM
trying pushing the brake in more when you move out of park. But some accords to have weak transmissions. You got a buddy mech? If you do have him check it out.
AccordCodger
09-14-2004, 01:50 PM
Also - common problem - the shifter cable freezes up. Since you say it's "hard" not "impossible" to get out of park, that's likely it.
No fix for the cable - have to install a new one.
bx10466
09-14-2004, 02:56 PM
OK, IT IS AN AUTOMATIC, IT DOESN'T HAPPEN ALL THE TIME AND IT'S NOT IMPOSSIBLE TO GET OUT OF PARK. iT'S MORE LIKE IT CATCHES BETWEEN PARK AND REVERSE. I HOPE THAT'S DESCRIBING MY PROBLEM A LIL BETTER.
94accordVTEC
09-14-2004, 03:17 PM
Most likely your problem then
ProMan
09-14-2004, 04:07 PM
I don't think it the tranny. It's either the cable or the shift mechanism. I had the same problem on my 92 Accord. It's very hard every morning. Later I found it's the sugar left on the shaft at the bottom of the mechanism bond together over the night (spilled coke on the shift stick area). I cleaned it up and that's it.
cruchible
10-30-2004, 06:04 PM
use your parking brake to stop the car before you put it in park.
illsmokeu
10-30-2004, 08:52 PM
i'd go with "proman", my friend had the same prob with his 91 accord, spray some wd40 on the mechanism bond, should work like a charm, and keep it clean from oil and especially drinks!
AccordCodger
11-01-2004, 09:17 AM
I still think it's probably the cable!
