Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Honda > Civic > '71-'87 Civic / CRX
Old 02-10-2002, 09:29 PM   #1
CRX91SiR84
CRX91SiR84
NOS vs. Turbo
I had an interesting conversation today at work, although I didnt understand some parts of it..... a friend of mine was trying to convince me of going NOS over a turbo..... i plan to be drag racing in the summer in 80 F + heat.... now, his idea was to use NOS to beat all the turboed vehicles. I drive a 91CRX with B16a swap...his reason was that the turbo would give me power below my powerband, and then when i hit my powerband i'd get a flat spot, and also that 80F+ degree weather isnt optimal temp for a turbo, so they will lose power.... at least thats what i remember and understood of the conversation... does this sound right? His idea was to lighten and polish my crankshaft, lighten flywheel, valve job, port and polish the head, new lighter higher compression pistons, lighter stronger connecting rods, all to get my revs up a LOT faster, along with other mods to raise all motor HP to around 300, and then to shoot a 100 shot..... will it be the turbo killer he's making it out to be?
CRX91SiR84 is offline   Reply With Quote
Old 02-10-2002, 10:02 PM   #2
90CRXZCSi
90CRXZCSi's Avatar
90CRXZCSi Normal reputation
Send a message via AIM to 90CRXZCSi Send a message via Yahoo to 90CRXZCSi
Go with the turbo. All NOS does is increase the chance to blow your motor. if you want to go with turbo, make sure you get a intercool er. The point of that is to cool the engine down for your 80 degree weather.
2004 Sonic Blue Ford Ranger XLT
2001 Liquid Grey Metallic Ford Focus ZX3
1995 Integra GS-R - Parting out
90CRXZCSi is offline   Reply With Quote
Old 02-10-2002, 10:15 PM   #3
Marc-OS
Marc-OS's Avatar
Marc-OS Normal reputation
Send a message via ICQ to Marc-OS Send a message via AIM to Marc-OS
Why pick one, why not have both?
10 PRINT "MARC-OS 0WNZ J00!!!"
20 GOTO 10
RUN
4/8/04 - My CRX is officially dead, RIP Lucy
Marc-OS is offline   Reply With Quote
Old 02-10-2002, 10:19 PM   #4
PFCfutrell
PFCfutrell
Send a message via AIM to PFCfutrell Send a message via Yahoo to PFCfutrell
I just want to clarify that an intercooler is not like an extra radiator, it cools the charge of air from the turbo after it's compressed. When air is compressed to say... 14.8 PSI a byproduct of that compression is increased heat. The intercooler cools that compressed charge of air before it hits the intake manifold but does not flow any coolant or anything, just air.
1991 CRX SI (black)
15.3 @ 88mph (stock motor)
'90 B18A1 swap
Custom exhaust
*2.25" piping
*two glasspacks (inline)
*polished flash-cut tip
*exits pass. side, front of rear tire.
'95 GSR 15" wheels
195/50/R15 Bridgestone Potenza SO-3's
AE Eng. front crossmember
Susp. Tech. 22mm rear sway bar
Susp. Tech. 1.8" lowering springs
Tokico Illumina 5-way adj. shocks
Powerslot rotors
Metal Master pads
Goodridge steel-braided brake lines
Red painted OEM calipers
Skunk2 short shifter
Skunk2 shift knob
GT Grant steering wheel
Red/black racing seats
PFCfutrell is offline   Reply With Quote
Old 02-11-2002, 12:20 AM   #5
SkyNex721
SkyNex721's Avatar
SkyNex721
Send a message via AIM to SkyNex721
Originally posted by 90CRXZCSi
[b]Go with the turbo. All NOS does is increase the chance to blow your motor.
Actually Nitrous doesn't do that. If you set up the car right you won't fry your engine. That's just a myth. The problem with Nitrous is that most people just slap it on and don't do anything else. You have to make sure that you are getting enough fuel to compensate the extra air that is coming in.
R.I.P. - You shall be resurrected.
SkyNex721 is offline   Reply With Quote
Old 02-11-2002, 12:36 AM   #6
90CRXZCSi
90CRXZCSi's Avatar
True, True. I was just considering the fact of the people who dont build up their motor and just slap on NOS.
Old 02-11-2002, 12:39 AM   #7
Phatwhippin_CRX
Phatwhippin_CRX
Send a message via ICQ to Phatwhippin_CRX Send a message via AIM to Phatwhippin_CRX Send a message via Yahoo to Phatwhippin_CRX
Unless you are running mid 14s or better OFF the bottle, then N2O is just for bitches. If you need the bottle to break mid 14s, you're taking the easy way out, and your car is still slow off the bottle. It's the bitch way out....
1989 DOHC VTEC CRX Si
C'mon, it's only a Honduh...can't be fast!
I AM the Anti-Rice!
Swap info, Turbo tech, and naked chicks!
Phatwhippin_CRX is offline   Reply With Quote
Old 02-11-2002, 10:35 AM   #8
CRX91SiR84
CRX91SiR84
Still no one has answered my question.... the engine will be set up right for NOS. I will make sure i get enough fuel runnin to the engine, and I plan to be running low 13's OFF the bottle.... will i beat turbo'ed cars running about the same?
Old 02-11-2002, 12:20 PM   #9
91HBSi
91HBSi
Send a message via ICQ to 91HBSi Send a message via AIM to 91HBSi Send a message via Yahoo to 91HBSi
It is impossible to say, "I will" or "will not beat turboed cars, with my Nitrous Oxide." If you are racing a car with the stock fuel system and just a street compressor with no intercooler... then you probably would beat them with your built engine and Nitrous. But that is not to say you will beat any turbo car. There still may be a lot of N/A cars that will beat you.
If it were me, I would go turbo. It is like Phatwippin' said, you are still slow... you just have a bottle too make you faster when it is engaged. The way I look at it is... Nitrous is like "Speed pills" some people take them to make them more on top of things for certain reasons, such as; to eccel in sports. Nitrous is just "speed" in a bottle.
Lexus SC300 (Kazera KZa 18"x8.5" 245/40 (front), 18"x9.5" 275/35 (rear)... put on hold.
Civic Hatchback Si (I/H/E, d16z6 head, H&R springs/tokico blues, etc.)
94 Prelude Si (Sold!)
Former PureHonda.com member since Dec. 00
"For to me, to live is Christ and to die is gain." Pilippians ONe21
91HBSi is offline   Reply With Quote
Bookmarks
Google
Web AF
