91 grand caravan 3.3
livewestside
09-12-2004, 05:07 PM
how big a job to replace the crank angle senser?
yogi_123rd
09-12-2004, 09:36 PM
One of your problem(s) may be with the neutral safety switch. It would explain not being able to start the car in neutral, but I'm not sure if it would cause a stall to a running engine.
You should also see if there are any diagnostic codes in the computer. Procedure follows:
Chysler computer codes (80-95 Chysler's):
Chysler faults codes are stored in the computer for up to 50 ignition starts. Each code is two digits. Beware that some problems can generate multiple faults codes. The code's meaning (i.e. faulty sensor) can be found by doing a web search using keywords "Chryler computer codes".
To obtain codes: Turning the ignition key on-off-on three times (don't start the engine) will put the computer into diagnostic mode. Watch the "check engine" light. Count the flashes for each digit which is followed by a pause between digits. Two digits to a code with the end ofthe list being code 55.
To reset the codes, turn the ignition key on-off-on 50-55 times (don't start the engine).
livewestside
09-13-2004, 09:15 PM
thanks for the message,
Well ok got a code 11 reading,
crank sensor, How big of a job, are the crank and cam sensors, to replace.
livewestside
09-13-2004, 09:17 PM
ok got a code 11, crank senser how big of a job to replace?
