99 dodge dakota 4x4 problem
mirage27
09-10-2004, 10:24 PM
the motor will not start up, it turns over but will not start i checked the relays and fuses all appears to be good, but i'm not getting any spark from the coil at all. I have changed the coil already and still nothing any help would be appreciated.
BleedDodge
09-12-2004, 02:42 AM
Computer might be shot.
Is the check engine light on?
mirage27
09-12-2004, 06:16 PM
No the check engine light has never come on, its just amazing that dodges computers go bad so often
timbo_lan71
09-16-2004, 11:26 AM
Check to see if the fuel pump is running while cranking the engine,if your missing spark and fuel pump I would suspect the crank sensor,PCM will not fire the coil or fuel pump without a crank reference.You should have fuel pump at key on for a couple of seconds if this is the case,but none while cranking.Its cheaper than a new computer and not hard to try.let me know,have some other ideas.
