1993 Pontiac GP GTP Keyless Remoterssrick 09-10-2004, 06:20 PM I bought a used 93 Grand Prix GTP that came with a keyless remote that doesn't work. Don't know if it's broke of just needs to be reprogramed. Anybody know how to program one of these? Saw some instructions on these forums but looks like they only work on newer Pontiacs. Thanks! Tom94gaGT 09-11-2004, 02:55 AM dont bother..i have a 94 grand am with keyless entry and you have to be about 3 feet away from the car for it to work, might as well use the key at that distance richtazz 09-11-2004, 02:41 PM In the trunk, on the passenger side, near the antenna, you'll see a wire harness not plugged to anything. Take a jumper wire and ground the harness, you should hear the locks cycle. After they cycle, press any botton on the remote, and that should do it. Unhook your jumper wire, and you should be good. rssrick 09-13-2004, 03:54 PM In the trunk, on the passenger side, near the antenna, you'll see a wire harness not plugged to anything. Take a jumper wire and ground the harness, you should hear the locks cycle. After they cycle, press any botton on the remote, and that should do it. Unhook your jumper wire, and you should be good. Thank you richtazz, I will try this tonight... rssrick... cockblocker 04-29-2005, 12:01 AM Thank you richtazz, I will try this tonight... rssrick... rssick, did this ever work for you? Which pin did you ground? Automotive Network, Inc., Copyright ©2012
