Bad Brakes?cks316 09-09-2004, 11:23 PM I noticed a squeeking noise coming from my rear brakes (more so my right rear brakes). However it only seems to make the noise under 15 mph. Also it makes the noise like this: squeek......sqeek.......sqeeek as it is not consistent. I just want to know if this is normal for my rear brakes or can that be the rotar. Any advice would be appreciated. treeboy38 09-10-2004, 07:30 PM sounds like a warped rotor....pull off the wheel and check the rotor for warping with your finger (makes sure the car has not been driven for a while) then rplace rotors and/or pads if needed RoraStar96 09-11-2004, 11:11 AM Get your rotors machined, it may help to get em resurfaced if warping has occured. The OE brake pads have wear indicators apparently, this may be it. Check the pads as well. Isnibs 09-11-2004, 05:40 PM All you need to know about brakes and pads but were unable to ask. Plus a whole lot more 'http://www.stoptech.com/whitepapers/warped_rotors_myth.htm' remove leading and following ' Automotive Network, Inc., Copyright ©2012
