95 with quad 4 starts and shuts downsnowboy811 09-09-2004, 11:02 PM i recently worked on my car and replaces my ecm, spark plugs, starter, battery, vacume hoses, and my spark plug shield with computer, it starts and then shuts down after 2 secs of running. i wonder if it is the camshaft module or the filter on my fuel rail someone help Mangoamerican 09-10-2004, 02:53 AM it sounds like the security system.. maybe you should check out the wiring for that richtazz 09-10-2004, 01:45 PM it is either the security system, or the oil pressure switch. The oil pressure switch is tied into the fuel pump relay, and will shut off the fuel pump if no oil pressure is detected after 3 seconds. It is located on the transaxle(drivers side) end of the cylinder head. It's easy to install and only $4 or so. snowboy811 09-15-2004, 06:47 PM i replace the oil pressure switch and still nothing,do you think it could be my fliter on my fuel bar right in front of the spark plug shield godenm 09-15-2004, 07:02 PM you say you changed the computer?'ecu' if so you have 2 get it reprogramed at delealer 'about 75$ Automotive Network, Inc., Copyright ©2012
