tire size HELPreynolds243 09-09-2004, 09:59 PM does anyone know what is the biggest size tire you can put on a 97 jimmy 4dr 4x4 with no lift. I was hoping that 30x9.5 would fit does anyone know furrybandit 10-16-2004, 09:09 PM i would like to know also for a 2001 i was hopeing for 31's clariveros 10-18-2004, 01:15 PM 30x9.5 fit fine almost with no rubbing, i use them on a 2wheel drive. 96jimmy4wd 03-09-2005, 11:56 PM 255 75 15 perelli scorpions fit nice (31 X 10.50) furrybandit 03-10-2005, 10:20 AM 255 75 15 perelli scorpions fit nice (31 X 10.50) I think 265' are 31's? oh well since then in Feb 05 I went a bought an 2005 Blazer ZR2 comes stock with 31's and 3" lift , so off to the Blazer fourm I go.....se ya 1996GMCJimmy 03-14-2005, 10:35 AM I have P235 75 15 and they still rub pretty tight against the sidewall. I didn want to go bigger cause I thought they wouldnt fit. My jimmy isnt raised or anything. 96JimmySLE 03-14-2005, 06:41 PM I think 265' are 31's? oh well since then in Feb 05 I went a bought an 2005 Blazer ZR2 comes stock with 31's and 3" lift , so off to the Blazer fourm I go.....se ya 235/75/15's are the stock size on a 4X4. I've had them on mine since my first tire replacement. My '96 came with 235/70/15. I went up to the 235/75/15. I think they just look better than the 70 series. GMCSeamus 03-15-2005, 06:32 PM I have a 96 Jimmy, and i put 235/75 BFGoodrich which are stock size. There isnt much room to add size. 30x9.50 will fit, you can fit 31x10.50 or maybe even 32x11.50's with some fender trimming, and a good amount of it for the 32's Let me know how it turns out ~DK 1996GMCJimmy 03-16-2005, 09:49 AM They turned out to fit pretty well. Actually, the Falkens I had on it before these were the same size exept they were LTs, and those rubbed the fender a little bit more. These new ones are the same size (P235/75/15) look more rugged, yet dont rub against the fender as much. jl2tx 03-17-2005, 06:25 PM i put Toyo 30 x 9.50 on my '92 4x4 - i have approx 1" clearence of all fnders and i have no lift kifts at all. fino 03-27-2005, 02:14 AM I have P235 75 15 and they still rub pretty tight against the sidewall. I didn want to go bigger cause I thought they wouldnt fit. My jimmy isnt raised or anything. Question? Is the rubbing a problem? I also have 235 75 15 on my 1995 jimmy and it rubs in a sharp turn its a 4x2 Should I consider smaller tires? rlith 03-27-2005, 09:49 AM When I had my 30x9.5's there was no rubbing, I get minor rubbing at full lock with my 31x10.5's (you don't have to trim the fender until you go to 32's) Automotive Network, Inc., Copyright ©2012
