Question to the "wise"anusemoon 09-09-2004, 11:50 AM beside battery and starter,,, what may cause a vehicle not to crank??? 99Intrigue 09-09-2004, 12:43 PM Ignition switch, open ignition circuit, no ground, alarm system (if installed). beside battery and starter,,, what may cause a vehicle not to crank??? newscarver 09-09-2004, 08:01 PM safety switch,in the gear shift,it is the reason it only starts in park...this can be a problem when a car gets older ponchonutty 09-09-2004, 08:21 PM The biggest problem is the VATS system. It is the black pellet in the key. Usually the tiny wires that go all the way inside the ignition cyl. break. You should notice the alarm or "security" light on an not going out when this happens. I have worked on more than I care to! Automotive Network, Inc., Copyright ©2012
