Convertible top Water leaksorrjohnf 09-08-2004, 10:31 PM I have a problem with a water leak between the top of the drivers window and the rubber gasket on the convertible top on my 2001 convertible. The water drips onto the armrest by the window switches. I know there are weep holes in the gasket to drain the water, and these might be clogged. This may or may not be the problem. Any solutions on how to clear the weep holes in the gasket, or other suggestions for correcting the water leak. yotatechie04 09-17-2004, 05:06 AM You could always replace the weatherstripping for a good solution to your problem...I'm not really sure as to how you could go about cleaning it...but I figure it would probably be much easier if you replaced it...plus, you can never fully tell if you've got those little holes completely cleaned out or not...so the cleaning may become a monthly, or weekly ritual...and that would suck. stomasze 11-17-2004, 12:03 PM I had the same problem with my confertible on the driver side only. I had to have the door adjusted so it won't leak anymore. I haven't had any problems since Regards and Good Luck, stomasze I have a problem with a water leak between the top of the drivers window and the rubber gasket on the convertible top on my 2001 convertible. The water drips onto the armrest by the window switches. I know there are weep holes in the gasket to drain the water, and these might be clogged. This may or may not be the problem. Any solutions on how to clear the weep holes in the gasket, or other suggestions for correcting the water leak. tabbiemorrill 11-04-2008, 11:39 AM Hello I am on here because I bought a chrysler sebring convertible and I friggen love my car but there is only one problem, When it rains I get water on the whole driver side floor and its not just a little bit of water it's a pool and I have tried spraying my top with some sealant and I have put goop on it but still when it rains I get tons of water it is so frusturating I even have to try to put a top over my car to block the rain but sometimes it still gets inside does anybody know of anthing I can do to stop this because a new top isnt too chaep! tabbiemorrill 11-04-2008, 11:41 AM :redface: :redface: :redface: :redface: :redface: :confused: :confused: :confused: :confused: :confused: Hello I am on here because I bought a chrysler sebring convertible and I friggen love my car but there is only one problem, When it rains I get water on the whole driver side floor and its not just a little bit of water it's a pool and I have tried spraying my top with some sealant and I have put goop on it but still when it rains I get tons of water it is so frusturating I even have to try to put a top over my car to block the rain but sometimes it still gets inside does anybody know of anthing I can do to stop this because a new top isnt too chaep!:mad: :mad: :mad: :mad: :mad: :crying: :crying: :crying: :crying: :crying: CoachFletch 10-17-2009, 11:09 AM I also have a problem with this issue. Mine is an 01 Solara. Can someone help? Automotive Network, Inc., Copyright ©2012
