Many many problemsjaoa49 09-08-2004, 02:45 AM 1.) I can't find a place to make a hole in my 96 camry for the Amp wire to go to the battary... 2.) my Break light turns on an off and I checked for leaks near tires and in the rims nothing... and checked the fluid level and it is in the middle of Full and Fill... 3.) My Dam AIR BAG LIGHT IS ALWAYS ON! 4.) My the warning thingy for my lights always turns on once in a while while the lights are on... 5.) I think I'm just gonna push it into a river.... Any help here? :disappoin :smokin: ProMan 09-08-2004, 12:04 PM I can help on #5. yotatechie04 09-08-2004, 04:28 PM Don't know about the amp wire, not that familiar with those models. You do need to add fluid to your brakes all the way to full and that should get rid of the nagging light. If the airbag light is always on, then that means there's a problem with the SRS system, and you should have it checked and serviced, although you could just disconnect the system from the car completely and not worry about it. (Your choice.) The light on the instrument cluster usually comes on when a bulb is blown or about ready to blow, and in some cases, which is somewhat common, a short in the rear main wiring harness for the lighting system. I also agree with ProMan, I can also help with shoving the damned thing into a river if it's causing you that much grief. Bmaintz 09-08-2004, 09:43 PM Be nice to your Camry & it will be nice to you....!! jaoa49 09-08-2004, 11:01 PM Woot i found a hole in meh car and my system sounds nice and loud :) Brian R. 09-09-2004, 10:34 AM I have found Camrys to be a PITA to get a wire through the firewall. yotatechie04 09-09-2004, 05:26 PM Be nice to your Camry & it will be nice to you....!! That holds true unless your Camry randomly decides to be cruel to you when you've been nothing but nice to it. What do you do in that case? jaoa49 09-10-2004, 01:40 PM Someone gimmy a good place where i can get toyota camry parts... when i put in the power wire i saw that the hose from my main engine block to my air filter had broken and I called everywhere to get one but unfortunatly that part isn't held in salvage places Brian R. 09-11-2004, 01:42 AM jaoa49 09-11-2004, 01:02 PM yeah well um as long as it doesn't cost me 75 bucks for it b/c thats a little tooooo high for a part like that Ty jaoa49 09-11-2004, 01:51 PM none of those sites had this part... :( I was told it was an AirFilter Cleaner but I don't think thats right seeing that its a hose Automotive Network, Inc., Copyright ©2012
