95 S-10 Tranny/Clutch Problems
cdmc1911
09-07-2004, 10:56 AM
I recently thought my clutch was bad because the knock out bearing was rattling and of course it was hard it get in gear (5-Speed manual).
When I pulled the clutch out it had fluid all over it so I also relapced the seal as well as the new clutch and knock out bearing. In less than two months the knock bearing is rattling again just as before. Suggestions?
busa_4
09-07-2004, 08:23 PM
did you replaced the clutch slave cylinder? it was probably leaking and probably still is. unfortunatley, you are going to have to replace the clutch disc and bearing again as it wont work very well with brake fluid on it.
cdmc1911
09-08-2004, 11:51 AM
The previous owner had replaced the slave cylinder a few years ago but I will definitely investigate it. Thanks
mike3028
09-09-2004, 11:57 AM
while you are in there, you might as well go ahead and replace the pilot bearing----i found out the hard way
