Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Blazer
Old 09-07-2004, 12:44 AM   #1
Butch Dennis
Butch Dennis Normal reputation
'90 Blazer driving me crazy! Will not start.
I'm new to this board and glad to see it. Lots of good information already, and great ideas. I'm hoping someone here can help me. I have checked the posts and don't see exactly the same problem.
My '90 full size Blazer (350 ci w/ TBI, all stock) quit while in parking lot, while idling. All stock. Full of fuel and I have checked all fuses. Turns over great. Have spark at coil and at plugs. Engine will start if I spray carb cleaner or gas down the throttle body. Fuel pump runs at key on. Bypass (jumper across) the fuel pump relay and getting fuel out of return line at throttle body (good flow w/ disconnected line). It won't start with fuel pump relay bypassed. I haven't checked the actual fuel pressure yet. I have voltage at the injectors. I disconnected the TPS to check startup at idle w/o success. I disconnected the timing wire (used to check timing at idle) w/o success. No trouble codes came up. Tried clearing computer by disconnecting battery for about 10 minutes w/o any difference.
I am leaning toward computer but I hate to just throw parts at it (to cheap and an old time mechanic, I like to fix what's wrong).
Any ideas on what I haven't tried? Thanx for any and all help.
Butch Dennis is offline   Reply With Quote
Old 09-07-2004, 01:19 AM   #2
BlazerLT
AF -Advisor
BlazerLT's Avatar
BlazerLT Normal reputation
Re: '90 Blazer driving me crazy! Will not start.
Check for a bad ground going to the injector pulse circuit and wiggle the connector going to the computer under the dash to make sure it is in tight.
Some good trouble shooting you have done. Open up the air cleaner and see if the injectors are spraying.
That will tell us a lot.
BlazerLT is offline   Reply With Quote
Old 09-07-2004, 02:43 AM   #3
Butch Dennis
Thanx for the reply.
I have checked all the grounds I can find. Don't know for sure if I have tried the one you mention. I have made sure the connectors to the computer are tight when I took it out to see how it hooked up. And no, the injectors are not spraying at all.
Old 09-07-2004, 02:49 AM   #4
BlazerLT
AF -Advisor
BlazerLT's Avatar
Trace the injector's ground wire which I think hooks directly to the computer seeing the computer fires the injectors.
Check for a broken or worn wire.
Old 09-08-2004, 12:39 AM   #5
Butch Dennis
Well, I now know what does not work (I think).
The fuel pressure at TBI outlet is 11 lbs.
The injector's ground wires are good to the computer connector, checked with ohm meter. Also, I have voltage at the ground wires at the computer with the ingition in start mode (poor man's node checker?).
Next I plan to check the injectors to see if by any chance they both clogged up at the same time (yea, right). Beginning to look more like a computer to me. Any other ideas?
Thanx.
Old 09-08-2004, 12:46 AM   #6
BlazerLT
AF -Advisor
BlazerLT's Avatar
Check if the injector's are getting the voltage pulse before you tear anything apart.
your check the voltage at the computer, now check it at the injector.
Old 09-08-2004, 02:05 AM   #7
Butch Dennis
Maybe I'm somewhat confused what your saying? There is voltage at the injectors first, goes thru the injector and ends up at the computer.
First post, I stated I found voltage at injectors; now I have followed it thru to the computer. Injectors still will not flow. Other than using actual noid tester, what else is there?
Old 09-08-2004, 02:10 AM   #8
BlazerLT
AF -Advisor
BlazerLT's Avatar
I'm sorry, Imust've missed that.
So you have voltage pulse at the injectors right?
Old 09-08-2004, 06:41 AM   #9
quaddriver
quaddriver Normal reputation
Send a message via AIM to quaddriver Send a message via MSN to quaddriver Send a message via Yahoo to quaddriver
all you need to do is buy or borrow the GM TBI 'noid lite from autozone.
injector flash = ecm not totally gone
at the same time, the ign is somewhat independant of the ECM. only the est circuit is controlled, with total ECM failure the ign will still pulse but that does not mean the ecm is listening.
while cranking, use a timing light to check base timing (it will be slow, but it will work) rule out timing problems.
report back.
quaddriver is offline   Reply With Quote
Old 09-08-2004, 11:37 PM   #10
Butch Dennis
I just love/hate Autozone. Sometimes they are just great. The noid light from them was just $7. Should have got it a week ago.
No light with noid installed. Still have power to injector/noid light and thru to computer, just not being operated.
Base timing good.
Time to start looking for a computer?
Old 09-08-2004, 11:43 PM   #11
Butch Dennis
BTY, Autozone lists two computers for this vehicle (#01227747 & 01228747), listed at $75 and $70. Any idea what the difference is?
Thanx.
Old 09-09-2004, 12:01 AM   #12
BlazerLT
AF -Advisor
BlazerLT's Avatar
Can you answer my questions, do you have an injector voltage pulse!
Is there voltage going to the injector?
Old 09-09-2004, 01:53 AM   #13
Butch Dennis
I thought that's what I said. There is still power (voltage) to injector/noid light and thru to computer. While turning over the engine, the noid light does not light up.
Are you asking about something else?
Old 09-09-2004, 02:00 AM   #14
BlazerLT
AF -Advisor
BlazerLT's Avatar
Re: Re: '90 Blazer driving me crazy! Will not start.
Nope, that is it.
Sounds like something is wrong with the ignition switch or something.
Have you checked all fuses?
Old 09-09-2004, 10:55 AM   #15
tbischop
tbischop Normal reputation
Ignition coil. Controls injector pulse.
A faulty coil will cause no pulse.
tbischop is offline   Reply With Quote
Bookmarks
Google
Web AF
