Driver 1? Driver 2? DIC won't change!!jckelsey 09-06-2004, 10:24 PM Just bought an 02 Trailblazer LT and supposedly it will save settings for 2 drivers. No matter which remote I use, 1 is labeled '1' and the other is labeled '2', the DIC always says 'Driver 1'. What gives!?!?!? dxve 09-07-2004, 02:46 PM We just bought an '02 LTZ. You need to use the DIC to tell the truck how you want it to recognize the different remotes. It sounds like yours is set to not recognize #1 or #2 so you get the default which is driver #1. Within the DIC menus, you can tell it to recognize the key fobs upon "unlock", at ignition or not at all. Just select the one you want. We set ours to "not at all" because every time I opened my wife's truck 17 motors whirred to life to adjust the seat, the mirrors, the lumbar support... even if I was just getting my sunglasses. so now I just use the buttons on the door to select driver 2 as I get in. Check your manual, but I think to get into the DIC menus, you need to select Driver 1 or 2 on the door buttons, and then press and hold the "enter key" on the steering wheel. after a few seconds, it chirps and you can navigate the various options, similar to setting up your cellphone. Good luck, hope it helps, Dave jckelsey 09-08-2004, 10:08 AM Well therein lies the problem I suppose. There are no buttons on the door at all. I thought the buttons on the door were just for the seat memory. Is that not the case? Thanks Johnny C 09-19-2004, 09:47 AM Try using the kye fob to lock or unlock the doors before you start the engine, then it should recognize 1 or 2. dxve 09-20-2004, 09:19 AM The buttons on the door control all driver memory functions in our car. Push button 2 and the seat goes to the memory position, the mirrors adjust, even the programed radio stations are recalled for driver 2, along with the settings you select in the DIC. Now if I could just figure out how to get it to stop defaulting to driver 1 every time it's started... Hope that helps, Dave RebeccaLee 02-04-2005, 11:41 AM how DO you get the recall to default to driver 1? My husband & son use driver 2--they are very tall. I am the primary driver-so when I get in & push driver 1, then get out, get back in within 1/2 hour or so, it defaults to driver 2! Needless to say, I cana barely reach the pedals. this drives me crazy! Automotive Network, Inc., Copyright ©2012
