Tire Clickingfrogfrog 09-06-2004, 05:58 PM Hey guys and gals, I'm new to this forum and here because my car has a problem that I can't seem to figure out. It's a 1995 Toyota Corolla and all stock because it's not really the kinda car you'd want to rice up, but when I drive I can here a constant clicking coming from the front driver's side wheel. I checked for big nails and rocks in the tire but there's none and there's nothing sticking out that could be slapping the wheel inside or whatever. The noise is getting louder too, any ideas what it is? joykill 09-07-2004, 02:19 AM wheel bearings...maybe...its most likely all eaten up and will cost you about 200-300 dollars to fix depending on the shop 1988lude4ws 09-07-2004, 10:19 AM cvjoints could be loose might want to get them checked out. my sugg. take it to a good shop and have them checked out. wozzy 09-09-2004, 08:55 PM check it urself, jack up the wheel and take it off check the tyre check for nails and everything, then check the cv boots, then check is something is tied in ur steering column, someone once put a wire tie on mine and it clicked aswell and got louder as i drove more often 'sigh'. to check ur wheel bearing put the wheel back on and keep the tyre in the air and put it in nuetral hand brake up oviously and spin the wheel, and put ur ear next to it, it shouldnt make a noise, if u hear a grinding noise or a scraping noise of some kind then its the bearings, good luck Automotive Network, Inc., Copyright ©2012
