roller tip rockerswilfie27 09-06-2004, 10:38 AM I recently came across a set of Comp Cam 1.6 roller tip rockers. I was wondering if I would be able to install them on my 95 with a 4.3 without changing anything else. BlazerLT 09-06-2004, 02:26 PM Your engine is already a roller rocker motor. Why replace what is already there? wilfie27 09-08-2004, 05:37 AM The lifters are roller, the rockers are stamped steel. quaddriver 09-08-2004, 06:49 AM typically u dont change rocker ratio without checking valve clearance, so Ill do it for ya.....1.6 will fit the stock blahzer motor. however, roller tip are not worth the $$ - when running, the roller tip is simply dragged across the valve stem. no rolling occurs now roller fulcrum...they might be sexy and free up a couple valvetrain hp wilfie27 09-08-2004, 02:54 PM Well....the roller tips were free. I work at a place that throws stuff like that away. Waiting for an intake to come in in on a core to polish, they throw those away also. wilfie27 09-14-2004, 05:37 AM Well I finally installed the roller tip rockers and I moved the IAT over to the hole where the crankcase breather tube goes into the air breather and plugged the original hole. Don't know if actual HP gained but it does have some more pick-up. BlazerLT 09-14-2004, 05:46 AM Ah, the sensor will read colder and dump in more fuel. You will get more HP but lose a little mileage. wilfie27 09-16-2004, 07:59 PM I think I improved on the milage, 200 mi using 1/4 tank so far, I put in a Moroso pro coil ($1)in this afternoon but I couldn't tell if any improvement on pickup because it just rained and I kept spinning the tires. Worth the gamble for a dollar. Quaddriver is right about the roller fulcrum just waiting for a motor to come in with some on it. Usually get them out the door for $20.00. By the way I work at a engine rebuilding plant that doesn't re-use certain performance parts i.e roller rockers, chrome valve covers, oil pans and timing covers ( none for 4.3 yet ) etc... they also discard intakes cylinder heads and for most motors many still good. I just threw away 400 ea. 96-98 4.3 heads last month and still have over 13,000 heads in my warehouse. Sorry for the rambling. BlazerLT 09-16-2004, 08:26 PM huh coil for $1? wilfie27 09-16-2004, 08:35 PM When someone buys a rebuild they have to turn in their old engine. Some people don't take off parts that they could transfer over to their new engine i.e. chrome valve covers, roller rockers etc..., so some of us keep an eye out for such things, and $1 for a performance ignition coil didn't seem like a bad deal today. Some guys will buy a pair of cylinder heads for $25 to take home and rebuild themselves. Mikado14 09-16-2004, 08:40 PM Damn!!!! You must live near Jasper, Indianna! You must have gotten a few trannies from us lately. West Chester, Pa. Land of the idiots who go four wheelin' and think they can shift a xfer case on the fly! Keeps us in business. BlazerLT 09-16-2004, 08:56 PM LOL! I'd take a $1 coil anyday. wilfie27 09-16-2004, 09:22 PM Jasper is about an hour away but I work in the dissassembly, cleaning and repair plant. I manage the cylinder head warehouse but also certified in cylinder head identification and repair ( bolt hole repair, milling and welding ). Automotive Network, Inc., Copyright ©2012
