Which side is the S10 lean on?
movin2stereo
09-06-2004, 09:31 AM
I have a 98 ZR2 and she is now leaning on the driver side rear.I read on here somewhere that a company made a piece to correct this.It was cheaper than a new spring.My springs aren't broke either.
BlazerLT
09-06-2004, 02:30 PM
How much of a lean?
Check your torsion mounts.
Check your swaybar bushings and end links.
Check for weak springs.
movin2stereo
09-06-2004, 08:14 PM
Not much of a lean.I've noticed other S10s that do the same thing.
BlazerLT
09-06-2004, 08:32 PM
It's called the chevy lean and it happens to most.
Check your sway bars links and bushings for wear causing this.
It stopped my lean.
movin2stereo
09-08-2004, 08:13 PM
I checked and noticed that the mount on the driver side was totally messed up.The bolt that went through there came loose and has worn the hole bigger.I welded some washers on it and fixed that problem,but she still leans.The rubber bushings look to be fine though.
movin2stereo
09-08-2004, 08:14 PM
Thats on the rear.
BlazerLT
09-08-2004, 11:09 PM
Thats on the rear.
Replace the end links. Don't repair.
The holes are supposed to be a little bigger so the rubber bushings fit in there.
Replace them, they are really really cheap.
movin2stereo
09-12-2004, 09:38 PM
The rubber bushings weren't worn.The mount on the rear end itself was worn.
BlazerLT
09-12-2004, 09:44 PM
The mount, huh?
Please clarify.
movin2stereo
09-13-2004, 06:25 AM
The driver side mount on the rear end was worn.It's where the sway bar hooks on to the rear end.I couldn't believe it myself.
BlazerLT
09-13-2004, 03:42 PM
Now go and fix it.
Very cheap and take maybe 20 minutes.
movin2stereo
09-13-2004, 10:36 PM
I did.I welded washers on the rear end mount and still I have the lean.I hope somebody can remember the company that made some kind of piece that fixed this problem cheap.I know I read it on here somewhere?Just can't find it.
BlazerLT
09-13-2004, 10:45 PM
How about going to the parts store and getting the proper end link kit for it instead of ghetto rigging it up.
movin2stereo
09-13-2004, 10:54 PM
I don't think you understand.The mount is part of the rear end,not the damn sway bar.
BlazerLT
09-13-2004, 10:57 PM
Oh I see, the circle the link goes through.
Can you go to the junk yard and cut one out of another truck?
