this tb any good???
Google
Web AF
98whitegpgt
09-05-2004, 11:52 PM
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=7919242046&fromMakeTrack=true i won the auction, but i am having second thoughts. i need to know if it is any good??? the reason i dont know about it is because 20hp i think thats a little bit of false advertising!!!!
GoAndPed123
09-06-2004, 02:39 PM
well ive never had it, but almost everyone exaggerates on ebay, so dont think the whole thing's a scam cause he said it adds 20 hp when really its liek 10 or even 15
not much to do abotu it now, as long as u get it put it on and if it doesnt fuck up ur car dont worry about it
98whitegpgt
09-06-2004, 08:54 PM
any other input?
98whitegpgt
09-06-2004, 09:11 PM
also is that center divider used for anything, cause on this tb it is ground completely out. i know i heard it is supposed to strighten the air out, but isnt that what the screen is for??
AKWE-gt
09-06-2004, 10:02 PM
to bad there wasn't any air flow numbers to see how much more cfm this thing flows than stock. as for the porting and polishing this something anyone can do with a drill and a brillo pad type material. it would have been better if it was bored out and had a larger throttle plate installed, then i could see it having some bigger hp numbers, but thats if your engine required more air. if your engine has a bigger cam or if you bored out the engine then i could see the need to get a larger tb.
my opinion is that it's all "shock an awe" this tb has a nice spit shine but there's no way 20 horses galloped out of it. i removed that tb screen and seen an increase of 2-3hp and that was pretty restrictive.
98whitegpgt
09-07-2004, 11:29 AM
i just found out today that my uncle can do stuff like boreing out. he is a collecter of antiques, and he has a old machine in his basement that can do work like that. i think i will have him bore it out to about 68mm like the zzp one is, but where do i get that brass plate in a bigger than stock size????
98whitegpgt
09-16-2004, 09:16 PM
well tb was finally shiped today, but then it goes out right away for boring, its going to 67mm, but where do i get that plate from????
Google
Web AF
