ignition switch problemsmgibson 09-05-2004, 08:42 PM Wipers,radio, tail lights,A/C went out. I have traced it to the ignition switch and installed a new one. No matter what position I put the slider in ... the accessorys I listed above will still run when the Key is in the off position. When I disconected the old switch there was two plugs going into it. One of the places for a wire was burnt and it looked like someone had removed it from the plug and slid it on the top middle conector. It is a purple wire.( I never had power when the key was on accessory).If I try to wire it this way Everything still stays on. If both the connectors are put on and wired like it is supposed to I still have one pin not connected to anything. Am I missing a wire? I have looked and cannot seem to find the answer . Help Pease if you can. 89ltd 11-16-2004, 12:21 PM Wipers,radio, tail lights,A/C went out. I have traced it to the ignition switch and installed a new one. No matter what position I put the slider in ... the accessorys I listed above will still run when the Key is in the off position. When I disconected the old switch there was two plugs going into it. One of the places for a wire was burnt and it looked like someone had removed it from the plug and slid it on the top middle conector. It is a purple wire.( I never had power when the key was on accessory).If I try to wire it this way Everything still stays on. If both the connectors are put on and wired like it is supposed to I still have one pin not connected to anything. Am I missing a wire? I have looked and cannot seem to find the answer . Help Pease if you can. I have the same problem, I'm working on it now, I have power to everthing even when the ign switch is now plugged in! Please let me know if you find a solution. mgibson 11-16-2004, 07:30 PM I have the same problem, I'm working on it now, I have power to everthing even when the ign switch is now plugged in! Please let me know if you find a solution. Somehow I ended up with two hot feed wires going into the switch. It is supposed to only have one. It finaly got the best of me and I took it to a place that could trace it down and fix it. Seemed so simple after all that headache...... Automotive Network, Inc., Copyright ©2012
