turnsignalss10lowrider27 09-05-2004, 06:55 PM alright, im having a problem with my turnsignal.... my right turnsignal works fine, but my left one doesnt. whenver i use my left one it works untill i touch the brakes, then it sticks on.. what could this be from? and how can i fix it, i put a new blinker in and that wasnt it... also, im looking to buy a new truck this winter, like january.... its gonna be a 98 or newer s10 with a 4.3 and 5speed. either standard cab or extended, if anyone is looking to sell thers let me know... thanks busa_4 09-05-2004, 08:18 PM i have a 1998 ext cab 4.3l auto. 150k all maintenance done. 4700.00. check your bulb. it probably cross shorted inside the bulb and it is activating other circuits. movin2stereo 09-06-2004, 09:33 AM Make sure you have the right bulb also. s10lowrider27 09-11-2004, 06:06 PM also, when i put on my hazard lights they work untill i hit the brake, then they just stay on like the right turnsignal, still the same problems? BlazerLT 09-11-2004, 06:09 PM You are low on blinker fluid. ;) Check for blown bulbs. s10lowrider27 09-15-2004, 06:27 PM ok, well its not the bulbs, i changed them... i noticed that when i have my 4ways on and i hit the brake the all stop... its weird... any other suggestions... busa_4 09-15-2004, 06:41 PM check the brake light switch. it might have shorted internally. do you have a wiring diagram? you need a wiring diagram to chase down this cross short. 83XFIRE 09-17-2004, 04:33 PM first off, when your hazards are on and you hit the brakes, the lights are going to stay on, they are supposed to. They do that on all cars. You could try this, it worked on my g/fs dakota. Find the little noise maker for the turn signals. Make sure that its in all the way, or maybe take it out and clean the prongs. That was all it took to fix my girlfriend's truck's same problem. If not, then I dunno man. 83XFIRE 09-17-2004, 04:37 PM You could always try blazerlt's suggestion, and check your blinker fluid. Its right next to the washer fluid for your rear window. BlazerLT 09-18-2004, 02:11 PM Also, the hazards are on another clicker than the standard signals. bigblackone 09-18-2004, 07:27 PM i would check the blinker switch ... s/b able to get one under 20$ Mikado14 09-19-2004, 01:36 PM Sounds to me like the stem switch. There is only one wire from the brake light switch to the flasher switch. When you activate either right or left, the side you activate is removed from the brake light switch and the flasher circuit is activated. The four way circuit is essentially in parallel to the stem and it doesnot remove the brake light switch from the circuit upon activation, that is why the stop light switch will lock up the 4 way's. You need to troubleshoot a little, remove the 4 way switch (unplug it). If the problem goes away, replace the 4 way switch. If it doesn't, replace the stem switch. Automotive Network, Inc., Copyright ©2012
