98 gtp cutting outsurf2 09-05-2004, 06:52 PM :banghead: :banghead: i have been on here before about a problem with my gtp cutting out,thought the problem was ironed out no such luck.it will cut out at speed,sitting at idle any time with out warning,no history,check engine light nothing.after it stalls it will start up after 2min.with no problem.i have had installed to date:coil packs,crank pos.sen.,fuel pump,throttle body disassemble,flashingx2,promx2..it has been a real pain in the a$$ and costly,the gtp is not a reliable auto as i write...if any body has a good solution to this problem please advise me by e-mail or this board,e-mail amsa620@aol.com thanks :banghead: :banghead: gtp :loser: kustomkid54 09-05-2004, 07:14 PM I see fuel pump, but not filter. It's a cheap fix. I'd try that 1st surf2 09-05-2004, 10:30 PM i forgot to mention a fuel filter also Maifirehawk 09-06-2004, 02:56 PM Check your TBS, if you can put it on a Scanner that would tell you, mine did the same thing, it turn out to be the TBS, it show intermitten low voltage. Automotive Network, Inc., Copyright ©2012
