Paint Codess10blazerman4x4 09-05-2004, 11:12 AM I want to know if there any websites out there to find out what color is painted on your rig? BlazerLT 09-05-2004, 02:34 PM Check your door bro. Should have the paint code. vikman78 10-01-2005, 06:55 PM I've looked for the paint code on the door jamb but to no avail. Shouldn't it be a WA#. How do I get the code if not one there. Mine is a 98 2dr 4wd and is a forest green color. Anyone have any suggestions?? Turbocpe 10-01-2005, 08:11 PM I've looked for the paint code on the door jamb but to no avail. Shouldn't it be a WA#. How do I get the code if not one there. Mine is a 98 2dr 4wd and is a forest green color. Anyone have any suggestions?? I also have a '98 Blazer 2DR, 4WD, which is also green. Open up the glove box and find the SPI sticker sheet stuck on the inside. I have a "43U" for a color option, which GM calls "Emerald Green", according to the 1998 GM Blazer shop manual. That may not be exactly what you're looking for, as a "color code", but that does tell you the GM color name. If you don't have "43U" on the bottom of the list, post the number codes and I'll give you the color definition. blazee 10-01-2005, 08:23 PM I also have a '98 Blazer 2DR, 4WD, which is also green. Open up the glove box and find the SPI sticker sheet stuck on the inside. I have a "43U" for a color option, which GM calls "Emerald Green", according to the 1998 GM Blazer shop manual. That may not be exactly what you're looking for, as a "color code", but that does tell you the GM color name. If you don't have "43U" on the bottom of the list, post the number codes and I'll give you the color definition. Welcome back. I'm glad to see that a lot of the regulars have been returning the last few days vikman78 10-02-2005, 01:34 AM The code that I found is 92H. The code was in lower right corner of sticker; Is this right? Turbocpe 10-02-2005, 01:47 AM 92H refers to the cloth seat color, which is Medium Dark Pewter. You do not have a 43U? Do you have a 87U? I have 92H listed in the lower RH corner as well, as well as on the last line which is apart of the main codes. Look, and post, your numbered codes that you find near the bottom list of the main section of codes. BlazerBoyLT98 10-02-2005, 08:38 PM I am also trying to find the color for my 98. Having an issue myself! Turbocpe 10-02-2005, 09:09 PM Post your numbered codes near the bottom half of the main section of codes, from the SPI sticker located inside your glove box. Most color codes for the '98 Blazer appear to start with a number. If you post it, I can give you the GM color name. blazee 10-02-2005, 09:15 PM Yes the paint code will be a number followed by a letter. The number indicates the color The letter indicates what the color applies to..... "U" (upper) is the primary color. "L" (lower) is the secondary color (two tone) "A" (accent) would be the color of the stripe....etc BlazerBoyLT98 10-02-2005, 09:17 PM Thanks I will post when I have time to get out to my truck. Thanks again! I believe it is Cherry, or Dark Cherry. Pep Boys tried to sell me torch red, that didn't work!!!:nono: blazee 10-02-2005, 09:21 PM Dark cherry should be 94 I believe, so look for 94U on the list. BlazerBoyLT98 10-02-2005, 10:46 PM Who was the guy that posted the pics of his Blazer that was red with the silver on the bottom? The two tone paint one? It looks real sharp and clean? That is my exact Blazer! Let me know if you know what I am talking about. Thanks BlazerBoyLT98 10-03-2005, 09:56 AM Ok here we go, this is my exact Blazer, it is just TonyMazz's here is the link, anyone know the exact name of this color? http://www.automotiveforums.com/vbulletin/showthread.php?t=418208 Thanks guys! vikman78 10-03-2005, 06:28 PM Ok, I do have a 43U in the last row of codes. I would guess that should be the one, do you know the color name for that code and does this translate in anyway to a WA # for the gm paint codes? Turbocpe 10-03-2005, 06:54 PM 43U is Emerald Green, according to GM. I'll see if I can get the code, but I'm not sure of the outcome. Turbocpe 10-03-2005, 06:56 PM A quick search appears to show it is "WA177B". You may want to verify this. vikman78 10-03-2005, 09:38 PM A quick search appears to show it is "WA177B". You may want to verify this. That sounds correct there is also a code on the sticker that is U 177B, with a space between the U and the 1, Thanks for all of your help it is sure appreciated. tom3 10-03-2005, 10:08 PM Most codes are listed here: http://www.plasti-kote.com/plastikote/colorguide/index.jsp s10blazerman4x4 10-07-2005, 11:09 AM Wow im impressed this thread of mine finally has resurfaced still no paint codes for me lol i looked in glove box no code did find out i had 3.08 gears sticker in door tells me about tires lol. s10blazerman4x4 10-07-2005, 11:41 AM Ok found estimate from body shop many moons ago and they say it mite be dark blue metallic which in there computer does not exist anymore.Im off to find it in glovebox maybe its in there Automotive Network, Inc., Copyright ©2012
