Another head pollGenopsyde 09-04-2004, 11:44 PM The application is a 305 SBC. The head options are: 1. Vortec 350 heads milled down with a steel shim gasket. 2. World Products Torquer 305 heads. Genopsyde 09-06-2004, 08:50 PM cmon now...bunch of haters. DiabloGT 09-06-2004, 11:04 PM lol maybe none of the people know what head companies they are? blueturtle 09-06-2004, 11:07 PM i know a head company in a whore house haha DiabloGT 09-06-2004, 11:13 PM i know a head company in a whore house haha lol! which hoe is the best? i think amanda is! GTStang 09-06-2004, 11:33 PM The application is a 305 SBC. The head options are: 1. Vortec 350 heads milled down with a steel shim gasket. 2. World Products Torquer 305 heads. Straight mill or angle mill? to what size cc for the combustion chamber? Genopsyde 09-07-2004, 11:28 PM straight mill 61cc instantkevin 09-07-2004, 11:43 PM i don't know why you wouldn't go with the vortec. I have vortec 906 castings (not installed yet, engine swap still in progress). Vortec will give you the best flow out of the box, no porting necessary. Vortec = proven power. 305 heads on a 350 is not a good idea anyway. They are not made to accomodate the larger displacement. Genopsyde 09-07-2004, 11:45 PM my engine is a 305 Genopsyde 09-07-2004, 11:46 PM goin with vortec will drop my compression. I'm also sure that the torquer's will out perform the vortec's, most ppl just use the vortecs cuz you can get em for cheap. The price doesn't matter to me tho. I just want the best performance choice for my 305. instantkevin 09-07-2004, 11:55 PM whoops, yeah sorry. I was thinking you've got a 350. In that case.... put a blower on it. (in your words ;) ) well... there's been a lot of controversy about mix-matching 305 and 350 heads on different engines. I remember reading something from, I think, hot rod mag. They did a dyno with both types of heads and turned out 350 heads on 305 did not make any improvement in performance. but of course you can get different results with different particulare heads. I would go with what's logical, port/polish 305 heads, with good intake and cam. or Vortec and , put a blower on it. Genopsyde 09-08-2004, 12:00 AM the torquer 305's are performance heads from World Products. Genopsyde 09-08-2004, 12:00 AM so i'm sure the port and polish part is already taken care of. instantkevin 09-08-2004, 12:03 AM my reference didn't mention either, just my recommendation. http://www.americanspeedcenter.net/WorldP.asp Genopsyde 09-08-2004, 12:06 AM yea, the s/r Torquer 305 WP-042750-1 are the ones i'm talkin about. they have the same 58cc combustion chamber that my stock setup has. tacoma man. 09-08-2004, 04:38 PM lol! which hoe is the best? i think amanda is! Hey now, amanda is my girlfriend :nono: and she's not a HO! not yet any way. :lol: 351wStang 09-08-2004, 11:27 PM You looked into AFR's? Awsome flow numbers. Genopsyde 09-09-2004, 02:45 AM No I haven't, but I will now, thx. 351wStang 09-09-2004, 07:09 PM www.airflowresearch.com 89IROC&RS 09-10-2004, 03:43 PM . I have vortec 906 castings dude, just checking, but you know those are the less desireable castings right??? do not try to enlarge valve seats, and use a dual pattern cam with a little more lift and/or durration on the exhaust side to compensate for its lesser air flow. the desireable vortec castings are the 062 castings found on R code engine equipped CK trucks. just a sidenote to the conversation. 4onFloor 09-10-2004, 05:18 PM 305 heads on a 350 is not a good idea anyway. They are not made to accomodate the larger displacement. 305 valves handle the displacement of a mild 350 just fine. the only drawback is there designed smaller bores, so you get overhang into the cylinder area, but an hour with a grinder and problem solved. plus the 58cc jumps the compression a little compared to the 64cc 350 heads. now 350 heads on a 305 is well...like a 36 inch dildo....kinda pointless. unless you've got a blower Genopsyde 09-11-2004, 01:10 AM why is everyone voting for the vortec heads then if everyone realizes that they'll be bad on a 305? Genopsyde 09-11-2004, 01:11 AM remember, i'm keeping the 305, i'm not swapping in a 350. mike123 09-11-2004, 05:23 AM yea i got some vortec 906's i gota sell , cause i need money for a another camaro. 89IROC&RS 09-12-2004, 02:36 PM actually, the vortec heads will be AWESOME on a 305. so long as you keep the small valve sizes. you can either mill down the heads for smaller chambers, or run a small dome on the pistons, or a steel shim gasket, its very doable. the small valves will work great with the 305 bore x stroke ratio because the 305 is designed for low rpms, and the small valve ports on the heads will have great flow and high port velocities at low rpms, so youll have pretty stout torque from idle - 4500 rpms, which is what gets these cars movin in the first place. so once you handle the compression issue, you can get a nice balance of both worlds, the torquer SR heads will make great low end power, but the vortecs will extend your power band up a few hundred more rpms. so you could probly still run the 906 heads on a 305 seeing as you have to keep the small valve sizes to clear the bores. but some mild port work, three angle valve job, and some manley street flo valves would really make the heads flow some air. and still have high port velocity for better atomization of the air/fuel ratio. Genopsyde 09-12-2004, 10:53 PM ok, which would require less work, cuz i'm lazy? Genopsyde 09-14-2004, 10:55 PM ok, i guess i'll get the vortecs, but I know shit about porting and polishing, and 3-angle valve jobs, is there a how-to anywhere online? mike123 09-15-2004, 02:01 AM wanna buy my heads lol they've been siting in my garge for so long and i want something else instantkevin 09-15-2004, 02:16 AM 89IROC how do you like those 906 castings? I got mine from a pretty good company off eBay. completely redone, new springs, valves, 5-angle job, etc. Didn't find out about the downside to the 906's till after I bought them. Now I'm not sure if I want to put them on my engine. Everything this on this engine is going to be for super street performance, and I'm not sure how much these heads will set me back. What do you think about them? got any power numbers and/or specs? I've read in a couple places that these castings don't affect power too much. Genopsyde 09-15-2004, 01:10 PM Mike123, I probably would, but last time I tried to buy something from someone here, i sent the money and never recieved the item. It wasn't cheap either. 89IROC&RS 09-15-2004, 01:38 PM the 906 castings arent a death knell or anything, its just that their performance potential is limited, stock for stock the two heads, the 906 vs the 062 castings are pretty similar, i think the 062 has more exhaust flow. but where the 062 castings are better is the freedom to modify the valve seats for larger valves, and do extencive port work. the 906 castings have to pretty much be left alone, but a dual pattern cam like i said before should help that situation. for a street engine the 906 heads should do fine, but if you plan on doing any racing or high rpm performance, then youll want a set of the 062 heads that you can fully race prep. Automotive Network, Inc., Copyright ©2012
