Disable Your Daytime Running LightsBlazerLT 09-04-2004, 10:39 PM gman2153 09-05-2004, 11:19 AM just push the dome override button in 4 times till you hear a chime BlazerLT 09-05-2004, 02:24 PM But not everyone has the dome override bro, including me on my 1995. Trail Blazin 96 09-05-2004, 05:49 PM shoot my blazer you have to pull the fuse, but if i do that then my foglights dont work, but you can pull the fuse and put it back in and the foglights will work, but the drawback to that is you have to do it everytime you get in, and if you turn on the headlights and then turn them back off you have to pull the fuse again BlazerLT 09-05-2004, 09:03 PM No, I can do this on my 1995, you can do this on your 1996. Check for the relays in your glove compartment. onkyo 09-05-2004, 11:28 PM on both my blazers, 92, 96, you enagage the parking brake and they turn off, so i would assume there is a relay on the park brake that you could just open or close to get the same result. BlazerLT 09-05-2004, 11:47 PM That is more than likely what we are doing. Automotive Network, Inc., Copyright ©2012
