rear shock replacementwhite97ex 09-03-2004, 11:28 PM well...my driver's side rear is squatting. i believe i have a busted shock. when i approach inclines i can hear a very audible popping. there was some fluid on the lower part of the shock body and i could tell that the bottom leaf of the leaf springs was resting on the upper. i originally thought the spring was sagging until i noticed teh fluid on the shock. so i am getting a new set of rear shocks and i am sure this is a no brainer but what do i do to replace them. just unbolt them and put the new ones in? OverBoardProject 09-04-2004, 12:50 AM That's about all there is to shock replacement. Don't be suprised if you have a broken spring though, fried shocks won't usually cause the corner to sag. movin2stereo 09-04-2004, 08:38 AM Ya,shocks themselves don't lift.Unless they are air or have preloads on them. white97ex 09-04-2004, 11:22 AM that sux. oh well. i probably need to replace them anyway. i believe it has factory shocks still and it has 3 inch blocks out back. BlazerLT 09-04-2004, 07:20 PM Sag is not caused by shocks. A bad spring probably blew the shock. Don't install a new set of shocks on bad springs or they will be ruined just as fast. Automotive Network, Inc., Copyright ©2012
