Where is the fan resistor bank?ducttape 09-03-2004, 10:45 PM Where is the fan resistor bank? The blower motor only works on high so i think it is resistors. contacts on dash control is ok. Also had an auto starter installed think this is where problems started. Driver door window switch quit working also. How did cars get so complicated BIG-L 09-04-2004, 10:49 AM Where is the fan resistor bank? You must be referring to the Blower Motor Resistor and its behind the blower motor.You have to pull out the motor to get to the resistor to replace it and here is what it looks like.....~Larry~ http://www.rockauto.com/ref/ACDelco/15-8713.jpg ducttape 09-04-2004, 09:32 PM [QUOTE=BIG-L]You must be referring to the Blower Motor Resistor and its behind the blower motor.You have to pull out the motor to get to the resistor to replace it and here is what it looks like.....~Larry~ Thanks Larry, in my younger days i would have torn everything apart to find it. Now it seem i'll only have to take most of it apart. Thanks again Ducttape Automotive Network, Inc., Copyright ©2012
