Overheating problem!!!!!
SpEkTiC
09-03-2004, 09:32 PM
alright I need help my 89 celica has been over heating and the antifreeze has turned a rusty brown color I think there is a leak coming from the freezer plugs anybody else have the same problem....please reply... :banghead:
kenwood guy
09-03-2004, 09:37 PM
rusty brown??? is it mixing with the trans fluid????
SpEkTiC
09-03-2004, 09:46 PM
not that i know of
kenwood guy
09-03-2004, 09:50 PM
depending if your trans has a seprate cooler you might have a busted line in the radator (I Think) how does you trany act?????
SpEkTiC
09-03-2004, 09:53 PM
perfectly fine except for reverse if i drive in reverse for like about 0.1 miles it gets stuck in gear
kenwood guy
09-03-2004, 09:59 PM
hmm I think you need to fix your radator keep mind I said I think I had a proplem like this and there was a leak (external) your problem seems internal (I think)
SpEkTiC
09-03-2004, 10:05 PM
yeah i do believe its internal because i tried flushing it once and it was clear from the brown color for about 2 hours then it started getting brown again....
SpEkTiC
09-03-2004, 10:06 PM
so what would i have to fix the entire head or what ..
kenwood guy
09-03-2004, 10:15 PM
I would think so but because its internal you would have to replace it I think unless you can fix it ( I think)
SpEkTiC
09-03-2004, 10:22 PM
well thanx for the help...kenwood guy..
kenwood guy
09-03-2004, 10:26 PM
anytime
mebert225
09-13-2004, 11:11 AM
you shouldnt have to replace the head, just new gaskets and rebuild it, does the engine make any noises at all and are you beating on it, like revin high and shifting hard
SpEkTiC
09-13-2004, 12:55 PM
the enginedoes not make any noises and no i dont high rev or shift hard ........ and check this out i just changed the thermostat and the piece that goes into the engine was missing like it was twisted off and broke ........
