1995 Blazer will not start
mcd996
09-03-2004, 10:24 AM
Just replaced Battery, Starter, Starter and Soleniod on my 1995 Blazer LS. The vehicle just had a major tune up (400.00) and ran like new for a week. Now it will not start, no dash lights prior to starting, engine cranks, also notice no (fuel prime) before attempting to start. Also, checked all fueses. *Any assistance is greatly appreciated.
BlazerLT
09-03-2004, 12:11 PM
Check all fuses in the engine compartment and cab.
Also, check and replace the black ignition switch in the steering column.
mcd996
09-03-2004, 02:05 PM
Ok. I will give that a go.
BlazerLT
09-03-2004, 07:09 PM
Ah, wait, also, wiggle the pink wire under the steering column and see if the light come on.
MGoBlue102
09-03-2004, 07:43 PM
I ran into a problem a couple weeks ago where mine wouldnt start, tune up led nowhere, ends up, the shaft on the distributor itself was worn out. 300 bucks more to rip out the distributor and presto, it runs.
BlazerLT
09-03-2004, 07:51 PM
true, that could be an option, but start at the smaller things first before you go big.
mcd996
09-06-2004, 11:59 AM
Ok, checked all fuses in the driverside fuse center, all good. Next, couldn't locate any fuses in the engine compartment. Looking under the steering column and located a small black wiring link under the key tumbler. Is this the ignition switch?? Also, Haynes guide states remove the Air Bag system wire before disconnecting any other connections..Which is a pain in the "A" .
Should I find this pink wire before replacing the ignition switch??
Appreciate all the assistance//
Mike
mcd996
09-06-2004, 12:18 PM
Can you believe this, it has started after shaking a freakin pink wire...
Thanks alot for your insight. What preventive measure do I need to take to keep this from occuring.
Thanks A million
BlazerLT
09-06-2004, 02:16 PM
Thanks A million
You are very welcome, it sucks that one small wire has this much of an effect on the truck.
Glad I could help.
mcd996
09-06-2004, 02:18 PM
Really appreciate the assistance. Was there anything else I need to do to prevent this from occuring
BlazerLT
09-06-2004, 02:22 PM
Trace the wire and resolder the connection that is loose or install a new ignition module.
Try the resolder first.
mcd996
09-06-2004, 02:24 PM
Got it, again much thanks you've saved me a bundle.
BlazerLT
09-06-2004, 02:32 PM
Dealer would have charged you 200-300 to find this gremlin. ;)
mcd996
09-07-2004, 06:51 PM
I'd figured as much. Just goes to show, how valuable sites like these have become. In the case I can ever be of assistance to you or anyone else on these type of pages I'll keep this incident in mind
BlazerLT
09-07-2004, 11:06 PM
Thx! ;)
Rick Norwood
09-07-2004, 11:29 PM
Good Job LT! It sure seems funny how this faulty ignition wire seems to be getting more and more prevalent.
BlazerLT
09-07-2004, 11:32 PM
Thx BRO! :D
Yea, and unfortuneately, no one knows to look for it.
