95 blazer intermitent no start
blazerbob95
09-02-2004, 10:05 PM
My 95 blazer has failed to start 4 times for me. I had it towed to a repair shop. It started right away for them. They couldn't find anything wrong.
I recently replaced the fuel pump (very noisy), fuel filter( it was time), the injection assembly and spider ( it was leaking bad but the truck still ran), egr (could't pass emissions), wires & plugs ( maintenace).
I've got 217k on the beast and this the first real problems I've had.
I'd appreciate any help.
Bob
mcd996
09-03-2004, 10:15 AM
I'm experiencing the same problems. After investing 400.00 USD in a major tune up, the vehicle ran as new. One week later it will not start. The following was accomplished by me.
1. Replaced Battery
2. Replaced the Starter & Starter Soleniod
3. Replaced the Ignition Coil.
Note: During starting attempts, there are no dash lights prior to start-up, but the headlights are operational. Engine will crank, but no start. Also, no fuel sound before start. Any ideas, please assist...
BlazerLT
09-03-2004, 12:09 PM
Bob
I would check your CPI injector again and replace the nut kit which is the internal fuel lines in the upper plenum that go to the injector.
blazerbob95
09-06-2004, 12:48 PM
Are these the nuts that hold the lines in place?
BlazerLT
09-06-2004, 02:19 PM
http://www.tweaknews.net/img/after.JPG
The white lines are the nut kit.
Also, check to see if you spark plugs are getting spark.
blazerbob95
09-06-2004, 09:54 PM
Thanks I'll give that a try.
mcd996
09-07-2004, 06:46 PM
Thanks for the insight. Finally have the Blazer running after re-soldering the 12v pink ignition wire, located under the sterring column in the black ignition switch.
BlazerLT
09-07-2004, 11:01 PM
did I tell you the solder it?
