Door Ajar... did the searchMaximAvs 09-02-2004, 12:53 PM I did a search for the door ajar problem on the Rangers and the fix being spaying WD-40 in the latch. I wanted some clarification. Do you spray WD-40 in the "latch" on the door jamb, or inside the door handles, or remove the door panel and spray inside the door on the switch inside? Thanks. Sean freeclimber 09-07-2004, 12:45 PM You spray directly on the latch. It makes it's way down to the switch, which is mounted to the bottom of the latch. cbaldi 09-21-2004, 11:04 PM I had this problem too and WD40 in the door latch opening did the trick. After a frustrating search I couldn't believe how simple the fix was. Worked on my Sable too. Automotive Network, Inc., Copyright ©2012
