Replace 2.8 L with 4.3 L Engine?Lowell 09-01-2004, 09:34 PM I own an immaculate 1988 Chevy S-10 Blazer with a 2.8 L V6 engine, 4 wheel drive and manual transmission. The engine now has over 140,000 miles on it and I am thinking of replacing it with a rebuilt 4.3 L V6 engine. Is this advisable? Is it complicated and expensive? Are there special things to consider that aren't obvious? Can the drive train handle the extra power? Does mileage improve or decline? Thanks, Lowell M. DICKE BlazerLT 09-02-2004, 12:39 AM Drive the 2.8L into the ground an then swap a 350 in. You will need to swap some new engine mounts in but there is guide on how to do it. CW_racefan 09-02-2004, 01:28 PM Problem with either option is the transmission from a 2.8 will not bolt up to a 4.3 or 350. Swapping to either will require a new tranny. I went through this on an 85. Bottom line, if you're gonna do it, either go with another 2.8 or go all the way to a 350! (btw...a 4.3 and a 350 both use the same tranny bellhousing and bolt pattern) BlazerLT 09-02-2004, 01:33 PM ah, true, very true, forgot about the tranny. Lowell 09-02-2004, 03:22 PM Drive the 2.8L into the ground an then swap a 350 in. You will need to swap some new engine mounts in but there is guide on how to do it. Can you give me the name of the guide and where to buy it (i.e., Amazon, etc.)? Thanks, Lowell BlazerLT 09-02-2004, 05:13 PM check on google for s10 blazer conversion guide Lowell 09-02-2004, 05:22 PM Thanks. Lowell Automotive Network, Inc., Copyright ©2012
