08-31-2004, 05:57 PM
ENGINE Swap
this has been posted before. but o well. Oki want to put a 4.3L v6 in my truck i have a 2.2 4 cyl rightb now 95. I am tryin to c how much this would cost and if i could do the swap by myself or if i would need some echanic to do it for me. If its gonna be 3 grand and a lot of work i will just go with a turbo. ANyone do any engine swaps here?? and if so wat did u do about the tranny and wat not?
08-31-2004, 07:07 PM
Re: ENGINE Swap
i dont think il be 3 grand if you get a motor from a junk yard or something but a new one will be alot but i dont realy kno how much it would cost exacly
Sony cdx f5700 HU
Need 4x6s for the front but for now i have tweaters out of a blow 6x9
5" blaupunk2 ways for mids
fullrange box with 2 12s ans 2 tweets. they are shitty some sale yard stuff buts its ran off a boss 4 ch 400w
1 pioneer 12 immp 150 rms (its a peice of shit to but it gets the job done) in a sealed box with leaks
its ran off a old school jensen 250 watts bridged
09-01-2004, 12:02 AM
Re: ENGINE Swap
if you are going from a 2.2 to a v6 you should just go to the v8. It is the same amount of work and you get a bigger engine. if you play your cards right, and get a carbarated motor and then do it by yourself without a mechanic... you could do the v8 swap for $1000-1500!! so i would jump on that boat. You will need a tranny also with the engine. Then get the kit off the internet that includes a radiator, the frame mounts, the headers, and the book... HAPPY SWAPPING!!!
plans for my new car....
09-01-2004, 06:23 AM
Re: ENGINE Swap
c dude i dont need to be wasting gas. I just need a v6 cand plus witht he v6 i dont need to new headers and shit just new mounting brakets. I want to keep it simple. So any good tips for something like this
09-02-2004, 01:13 AM
AF -Advisor
Re: ENGINE Swap
don't argue with him, he is completely right.
A V8 swap will be more fuel efficient seeing if won't have to work as hard as the V6.
If you are swapping up from a 4 banger, go V8.
It is cheaper, more power for the money and has a lot more potential than any blown V6.
You need to listen to people who know what they are talking about instead of arguing when they give you proper advice.
09-02-2004, 01:17 AM
Re: ENGINE Swap
well ok dude well i will listen to him. But if i do this y guys need to help me out. Cause the v6 would have been wasy simple but v8 ehhhh. tell me wat to do where to get my stuff. and i am so down
09-02-2004, 01:22 AM
AF -Advisor
Re: ENGINE Swap
There is a manual to do this on Ebay and online, search through google for V8 s10 guide.
Trust me, you will be doing the same work for a V6 that you will be doing for a V8.
Make it count so you won't be disappointed.
09-02-2004, 01:35 AM
Re: ENGINE Swap
i just looked in ebya for it no go. Where else?
09-02-2004, 01:42 AM
AF -Advisor
Re: ENGINE Swap
google for it.
09-02-2004, 01:50 AM
Re: ENGINE Swap
all i can find is v6 to v8. can u guys help me out here?
09-02-2004, 10:42 AM
Re: ENGINE Swap
You Guys Are Right A V8 Will Be More Fuel Efficient Than A 4 Cyl But You Are Failing To Tell S-10kid That The Rear Diff Gearing Will Have To Be Lowered. Since The V8 Has More Power You Want To Lower The Gearing So It Brings The Rpm Down. The 4 Cyl Gearing Is Higher Because It Has Less Torque. If You Were To Keep The 4 Cyl Gearing And Drop In A 8 Cyl. For Exampe: Say The 4 Cyl Is Geared At 60mph To Have An Rpm Of 3000rpm (in Top Trans Gear Only) If You Drop In A V8 Well Then Your Rpm Will Be At ~3000rpm At 60mph And That Will Definetly Drain Into Your Fuel Costs. You Will Need To Lower The Rear Diff Gear Or Obtain A Tranny That Can Drop That 60mph Rpm To ~1500rpm. If Your Purchasing A Aftermarket Modified Tranny Then They Will Most Likely Ask You What Gearing You Want In It. If Your Purchasing A Used Stock Tranny Then Your Restricted To That Trannies Gearing Unless You Change It Yourself. Try And Get As Close To 1500 Rpm At 60mph As Possible Otherwise You Gas Mileage Will Be Affected Drastically. Good Luck!
09-02-2004, 01:15 PM
AF -Advisor
Re: ENGINE Swap
True, I honestly think s-10 is WAY over his head on this.
Too much highly technical engine and body work for someone with limited knowledge.
Not being rude, just being honest.
09-02-2004, 05:35 PM
Re: ENGINE Swap
I kinda agree with blazer. But like i can drop it in there and i kno about the gearing and wat not. my only prob is finding a kit to do this. But damn if i only had 3 'gs i can get a s-10 with a v8
09-03-2004, 10:24 AM
Re: ENGINE Swap
This Is Not Any Easy Swap S-10kid. There Is Mechanical And Electrical Skills Involved. Basic Hand Tools Might Be Able To Get It Done But Your Going To Want Air Tools And Other Specailaty Tools To Get The Job Done Quicker And Easier. If You Dont Have At Least 2 Out Of 3 Of These Things I Have Mentioned I Would Not Attempt. I Would Recommend Trying To Find A Turbo Kit That Bolts Up With No Modifications. I Am Assuming You Can R&r Parts. A Turbo 4 Cylinder Will Give You => Power Than A 6 Cylinder. Good Luck!
09-03-2004, 11:27 AM
AF -Advisor
Re: ENGINE Swap
It's not so much the putting it together.
The big problem is diagnosing a problem and fixing it if something isn't right after the install.
