EGR Valve replacement
beenblazin
08-30-2004, 05:47 PM
my 95 s10 blazer is not running good at all, im pretty positive that its a piece of carbon in clogged in my EGR valve, but im not exactly sure where it is located, if anyone can help, please do
Stiletto
08-31-2004, 07:47 PM
ARE YOU GETTTING ANY SES LIGHTS? SMELLL GAS AND ROTTEN EXHAUST , AND GAS MILAGE GETTTING WORSE AND WORSE TEN IT WOULD BE YOUR CPI UNIT ? THE GAS LINES DRY ROT AND FRAY AND ESCAPES ALL YOUR FUEL . PLUS SPUDDERING AWAY , MY 92 JIMMY HAD THAT . INSTEASD OF CHANGING THE $350 PART I HAD A SHOP RE & RE NEW GAS LINES $185 AS FOR THE EGR THAT IS BAD ON MY 97 SS CAMARO LIMITS THE TACK TO 4300 . AND SETS THE SES LIGHT HAVEN'T THE TIME OR $ TO FIX IT YET IT IS BEHIND MY PLENUM ON MY CAMARO UNSURE OF 4.3's GOOD LUCK ,STILETTO
Stiletto
08-31-2004, 07:49 PM
oops alot of mispells and 43,000 rpms not 4,300
tom3
09-01-2004, 01:29 PM
Front of engine just below the rubber air cleaner connection, round about 2 inches in dia. Two bolts, 10mm socket, unplug wires and remove. Push back center pintle and blow out carbon, may fix it.
BlazerLT
09-01-2004, 03:53 PM
check her for a picture of the EGR valve.
You will have to remove the complete air filter assembly and remove the electrical connector to the IAT just under where the hose connects to the engine.
Here is the pic:
http://www.tweaknews.net/images/egr1.JPG
metallica21156
09-02-2004, 10:05 PM
i just pulled my EGR. some carbon was in it. the only thing i removed was the intake tubeing and with the truck off i put a big rock on the gas all of the way down. this gives you more room. i used a 10mm wench and socket. never touched the intake body. the EGR slide between the alt and tension pully. you don't even need to pull the belt. when i had mine off i did the EGR mod and put it back on. just remember to remove the rock before starting. i didn't and shut the egine off at 4,000 rpms. good luck. took about a hour to take off and a hour to put back on. if u want the EGR mod specs i still have them. it does not make the SES light come on. it works very well.
BlazerLT
09-03-2004, 11:56 AM
Do you have any proof of this EGR mod doing actually anything for good?
Better gas mileage?
Better 1/4 mile times?
Does your engine ping and detonate now?
metallica21156
09-03-2004, 03:47 PM
it's supposed to get better mpg. about 2.hesitation is almost completly gone. it doesn't ping or anything like that. it runs like it would woth out it but the performace is better. pulls up a hill better. never ran it in the 1/4 mile yet. but i will. the other things i have is. Glasspack exhuast,ITG racing cone filter and the EGR mod. no engine problems.
BlazerLT
09-03-2004, 04:46 PM
When you run your truck hooter, detonation does occur even if you can't hear it and the knock sensors retard the timing which raises fuel consumption.
No sense installing it, your knock sensors will alter the engine anyways.
metallica21156
09-03-2004, 05:37 PM
what would happen if i disconnected the knock sensors? besides maybe a SES light?
BlazerLT
09-03-2004, 06:02 PM
Your knock sensors are crucial for proper computer timing and the engine will litterally run like crap and defulat to ultra rich condiiton.
metallica21156
09-03-2004, 09:12 PM
is there any way to test to see if it's being retarded by the knock sensor?
BlazerLT
09-03-2004, 09:18 PM
a computer Scanner
