Anti-Lock brakes-Come on too soon
F-106 Delta Dart
08-30-2004, 01:32 PM
2001 S-10 When I drive on gravel roads the anti-lock system seems to engage much to quickly. This happens at slow speeds and higher speeds. Is there some adjustement that can be done to the system or better yet can I disengage it? The reason being is that I use it on a mailroute(410 stops)and it's very annoying to have the system always on. If I could somehow adjust it that would be perfect. Any idea's? Thanks! John
movin2stereo
08-31-2004, 06:24 AM
Pull the fuse,but then you will have to look at the bright red light on in the dash.
busa_4
08-31-2004, 02:11 PM
That Is Going To Happen Because There Is No Traction Most Of The Time. Your Best Bet Is To Remove The Fuse As Movin2stereo Suggests. There Is No Adjustment. One Question. Did You Change Your Factory Rims And Tires To Aftermarket? This Also Could Mess Things Up.
F-106 Delta Dart
09-02-2004, 08:20 PM
No it's the original rims and tires. So it's safe to pull the fuse? Thanks! John
busa_4
09-03-2004, 10:02 AM
Yes, Go Ahead And Do That.
