'00 LS2 Power locks don't unlock when key is removed from the ignition
I have a 2000 SL2 with power locks. Normally when the key is removed from the ignition, the locks unlock. This no longer happens. I have to use the interior switch. The power locks work otherwise without any problems. They lock when I put the car in drive too. They work with the interior switches as well as the keyless entry so I am perplexed. Is there a fuse or a module that needs to be replaced or is it something with the ignition switch. Any input or ideas would be helpful. Anyone with a similiar problem. Trying to avoid a trip to the dealer. Thanks in advance.
