Primeing the Oil SystemMidnight_Outlaw 08-29-2004, 07:04 PM Oil is supost to come out the top of the lifters right? (420a model) What if its not? I primed the system, i must rotated the crank like 30 times. Still no oil out the top. Midnight_Outlaw 08-29-2004, 10:15 PM Ok i found out the offical name is lash adjusters. I dont even think i am getting any oil pressure at all though. Could it be because i am doing it with a wrench, so im not going fast enough to even pull the oil up the pick up tube? kjewer1 08-29-2004, 10:29 PM You have to use the starter ;) The oil pump wont be very effective at .3 RPM :D guitarXgeek 08-29-2004, 10:33 PM How do you do that again? Just disconnect the starter relay and turn the key over and hold it? kjewer1 08-29-2004, 10:38 PM dissconect the ECU fuse, or the coil pack, etc. You need the motor to turn over without starting, thats all. Give it 10 second bursts (so you dont overheat the starter), say 3 times or so, with a half a minute between them to let the starter cool. guitarXgeek 08-29-2004, 10:43 PM So three 10 second bursts will be enough to prime a new turbo? Midnight_Outlaw 08-30-2004, 12:22 AM All right thanks, i hope that works. I will try that once im done with the wireing harness. kjewer1 08-30-2004, 03:05 AM Its always been enough for me. I tried it on a friends car with the oil feed line disconnected from the turbo. Its started flwing oil imediately. Midnight_Outlaw 08-30-2004, 07:13 PM Ok i cranked the starter 3 times for 10sec. With the 30sec breaks in between. But still no oil is coming out of the oil feed line to the turbo... I think i might be screwed. I dont think any one put greese on the oil pump before it was installed. Could this be why? If it is then how can i get it working with out tareing out the oil pump? What if i put some oil in the oil feed for the turbo and let it drain into the oil pump? Life she is a bit of a itch :banghead: :banghead: Midnight_Outlaw 08-30-2004, 09:23 PM Never mind guys, i got it. It just took a few more cranks, Then oil spewed all over my car lol. I got it running, it is idleing great! Cant wait till tomorrow when i get to take it out on the road again! It has been much to long. kjewer1 08-31-2004, 02:41 AM Glad it worked out. Sometimes you just wont get oil flow at crankingspeed from a new pump, and starting it up is the only way to get it working. It starts flowing so quickly at 7-800 rpm that it doenst hurt anything anyway, in my opinion. Automotive Network, Inc., Copyright ©2012
