HHHHHHHHHEEELPPPP.... Steering box repairLilbit01692003 08-28-2004, 03:01 PM Any help, info, advide, links, hints, tips.. Hubby is having a hard time getting this fixed... thought the PS pump was going bad.. noticed, it was all leaking in soon as he poured it in.. has been trying for days to get the pitman rod off of the steering box.. in order to get the seals out that are bad.. bear with me... Im in here looking for info while he is out in the driveway getting more and more aggrviated as the minutes pass.. and Im not real sure of spelling. I thought it was the pinnion, he told me nooo its the pitman rod.. so anyways, anybody out there have any advie or info to share ??? Thanks in advance. Linda Lilbit01692003 08-28-2004, 03:02 PM Any help, info, advide, links, hints, tips.. Hubby is having a hard time getting this fixed... thought the PS pump was going bad.. noticed, it was all leaking in soon as he poured it in.. has been trying for days to get the pitman rod off of the steering box.. in order to get the seals out that are bad.. bear with me... Im in here looking for info while he is out in the driveway getting more and more aggrviated as the minutes pass.. and Im not real sure of spelling. I thought it was the pinnion, he told me nooo its the pitman rod.. so anyways, anybody out there have any advie or info to share ??? Thanks in advance. Linda Im sorry ya'll.. this truck is a 1993 Ford Ranger Splash. freeclimber 08-28-2004, 05:21 PM You need a pitman arm puller. You can rent one or borrow from most autopart stores. However, it can still be a bear to remove. I've had to put the whole assy in a vice and heat the arm with a torch, while pounding with a hammer and cranking with a socket/breaker bar. Lilbit01692003 08-28-2004, 07:29 PM You need a pitman arm puller. You can rent one or borrow from most autopart stores. However, it can still be a bear to remove. I've had to put the whole assy in a vice and heat the arm with a torch, while pounding with a hammer and cranking with a socket/breaker bar. Freecliber~ Thank you for the reply, he did get it off, he said he used a yoke, a whole can of Yeild, and a hammer... he didnt have anything to heat it up, excpet for the heat of the day and humidity.. LOL now, he needs to get the bad seals out of there, he said he put it all back together , and on the truck, and he's gonna fill her up with fluid (Steering) and then cranck the truck, and use the hydrulic pressure to blow them out.. as he sat there with a screw driver trying to get them out, and its not happening... trust me, I'll be back on here tommorow Im sure looking for more advice.. THANK YOU! Lilbit01692003 08-29-2004, 05:01 PM Well here we are, ummm day 4 or 5 now... He did get the bad seals out, and went to AutoZone and bought a Power Steering Repair kit, that has all the seals in it he'll need... problem now, the seals he has, and the things that came out, are all of different thickiness.. hope this is makin sense, what he has to go in there, is to thick compared to the amount of room that is there, and what came out~ any ideas??? there is a snap ring, pressure seal, washer, washer , and another seal from what I can remember... he's out in the garage ,Im in here.. :0) freeclimber 08-30-2004, 02:29 PM Just get another steering box from the junkyard and put it in the truck. The extra one can become a hobby and when it's done, you can use it for a boat anchor. Automotive Network, Inc., Copyright ©2012
