Preping for turbopantlegz 08-28-2004, 01:19 AM ok so I finally decided to turbo my ka and just wanted a few opnions from some of you. I have a 92 240 with the stock ka no mods yet.. but I keep getting mixed responses on whether or not I need to get a forged bottom end, connectiong rods and pistons, or if it'll be safe to run 5-7 psi on the stock internals. For the time being I plan on running a rebuilt t25 from a sr, sr SMIC, and some sort of BOV just haven't decided yet. so really my question is what would you do in terms of reliability should I rebuild it so when I can afford a better turbo I don't have to worry about it. or just go ahead and "throw" the turbo on and pray I don't break something or everything and then do the rebuild when I can afford it? klohiq 08-28-2004, 02:45 AM #1 how many miles are on the engine and does it appear to be in good condition? #2 get a compression test on all 4 cylinders and make sure they are within spec nissanfanatic 08-28-2004, 11:21 AM Stock bottom end is good up to around 10-12 psi just as long as it is in good condition. Do a compression test. pantlegz 08-28-2004, 02:20 PM well I did a compression test on it yesterday came out low 130-140 on all of them, but it wasn't done right becasue I forgot to release the fuel pressure...lol oh well I'll try to get another one today. oh and there are 134xxx miles on it nissanfanatic 08-28-2004, 02:45 PM ahahahahahaha. Forgot to release the fuel pressure. Yea you need to do that. Make sure to hold the throttle open as well and disconnect the coil wire from the distributor. Mine has 132k on it and came out 160-165. pantlegz 08-28-2004, 03:48 PM yea I did that but didn't even think about the fuel pressure lol.. it's all good though I'll get it done a little later today.. nissanfanatic what kind of turbo setup are you planing on running and did/are you going to rebuild your engine first or when you feel the need for more boost? nissanfanatic 08-28-2004, 05:46 PM My setup is: Garrett T04B .60ar compressor/.96ar turbine (hopefully I can find a smaller one soon) Revhard manifold Turbonetics 35mm evolution wastegate Greddy Type-S blow off valve Vortech FMU (not for long) Walbro 255lph Import-Autoperformance oil lines Shitloads of fittings, piping, and hoses from Ace Hardware As you can see, there are a few things I am going to change. As for the engine rebuild, I feel the engine is still very strong and will handle the upgrade pretty well. What I plan on doing is rebuilding an engine on the side with a set of forged pistons. Rods are good up to 20psi or more. pantlegz 08-28-2004, 06:35 PM yea a second engine was my other option too but I think it will set me back too far for now, so after I do the compression test correctly. I'll decide whether or not I need to rebuild it or just get the turbo setup on then worry about the rebuild...Thank you for your help and advice nissanfanatic 08-28-2004, 06:46 PM No problem. Just PM me if you have any more questions. You are on 240sxforums too right? pantlegz 08-28-2004, 08:09 PM yea I'm on there too haven't been for a while, lately I've been at freshalloy but I'll start checking there too nissanfanatic 08-28-2004, 08:44 PM You can PM me there too. Automotive Network, Inc., Copyright ©2012
