JGC Laredo 2000....ABS Light is on...Pls. Helpprietopr 08-27-2004, 05:26 PM Will really appreciate any help or advise you can give me. The Jeep is breaking fine but light turns on after driving for a few blocks. ????? JDPascal 08-27-2004, 08:08 PM It has probably set a code. It would be good if you had a scan done. Other than that. check the wheel speed sensors for damage. If you have access to a manual, you will find troubleshooting charts in there. any one else want to jump in here? JD YtseJam454 08-27-2004, 08:55 PM yeah, since when is it fine when your Jeep breaks? Oh you mean Brakes :lol anyway, is your ABS light the only light that's on? If so you need to scan the abs module. You need a scan tool. hundahunta 08-28-2004, 11:12 PM possible a rear abs wheel sensor on diff.. prietopr 08-30-2004, 08:53 AM It has probably set a code. It would be good if you had a scan done. Other than that. check the wheel speed sensors for damage. If you have access to a manual, you will find troubleshooting charts in there. any one else want to jump in here? JD JD : Thanks very much for your reply. Will do. prietopr 08-30-2004, 08:59 AM yeah, since when is it fine when your Jeep breaks? Oh you mean Brakes :lol anyway, is your ABS light the only light that's on? If so you need to scan the abs module. You need a scan tool. That's the only light that is on. Will go for scanning after taking a brake. Thanks a lot. prietopr 08-30-2004, 09:05 AM possible a rear abs wheel sensor on diff.. Thanks for your help. It is appreciated very much. Automotive Network, Inc., Copyright ©2012
