????'s about sr20 swap into S13
Google
Web AF
Josh95cx
08-26-2004, 05:18 PM
I have a 89 240sx hatch with the sohc KA, I was wondering if i can use the sohc MAF in my sr20det swap, Also I was wondering what clutch to use. The last question is if I have the motor,tranny, new manifold and dump pipe, ecu, ignitor, harness, FMIC, new walbro fuel pump, B.o.V, boost controller, what else do I need? Thanx this is my first nissan, and i wan't it done right.
Josh95cx
08-26-2004, 05:19 PM
Also I have a 5-speed and plan on getting a LSD, and using my stock driveshaft.
winstonusmc
08-27-2004, 12:20 AM
you will need some sort of piping for the heater hose. Check autozone on pipes that will work. The stock SOHC MAF will work, thats what I run. You can stick with the stock radiator, it is the same thickness as the SR one, I measure them both. Or upgrade to a Koyo, $200 for copper or $300 for aluminum.There are many clutches out there that are made for the SR, check enjukuracing.com. They have good prices. Dont forget to upgrade your whole exhaust, not just the downpipe. Good luck
Josh95cx
08-28-2004, 01:46 AM
I have got a hose kit from heavy throttle, and a act clutch, any mods to the stock sohc maf to use it with the sr?
racer98
08-28-2004, 02:02 PM
too much of my shock yes you can use a SOHC MAF for it :)
Google
Web AF
